Nissan Maxima Suspension in a cb7?
    I was lookin at the suspension on the 86-89 Nissan Maxima its looks almost the exact same suspension on the cb7. It has the same nissin brake calipers and the same 4x114 lug pattern could it be possible if I could do a rear disc swap from that year maximaon to my cb?
    "Cocaine's a hellava drug"
    You serious? Try it.
    Gary A.K.A. Carter
    [sig killed by photobucket]
      you know the 92-93 ex, se, and wagon have rear disc right?
        try it. if you can get if for cheap or try to put it on another cb7 in the junkyard.
        Cali.Dumps.Harder.
          yea i wanna do it cause this old maxima is on part of my property and the owner has moved and left it. it doesnt look moveable so i mess around with it and noticed the suspension so i gonna start r
          researching on it..
            only way to find out is if the upper control arm and all trailing arms are identical. and if they have identical holes for the bolts. most def let us know though
            Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
            -(B-Pillar Bar Originator)-
