anybody know what i need to do in order to have the p13 ecu work well. i have a h23a3 non v motor swap running with a pt3. im jus wondering if i could use the p13 ecu since it came with the motor swap. it plugs right in and starts up. but it doesnt rev like i guess it suppose to. any help please
can i use a p13 ecu in my 90 honda accord lx
Originally posted by deevergote View PostCorrect. The P13 is for the H22, and will not run an H23 correctly. Get a P14, or find someone to chip a P06 and tune it for YOUR motor (not a generic tune). Those are your options.
For now, I'd stick with the PT3... but don't drive it hard. Drive it like it's broken.
Why would that be the only difference? VTEC is essentially two camshafts in one... so the fueling for a VTEC motor is completely different.
You are assuming that because the ECUs and engines are named similarly that they are similar... and honestly, in terms of tuning, they aren't very similar at all.
