Hey guy's I'm very sad to say my Cb7 was involved in a accedent on the front driver's side.... Luckly nobody was hurt is the best thing but the cb was hurt... It had blown the 80 amp fuse *I belive* It busted the radiator, condencer, bumper and support were toast ( but yet the blinker was fine ) it took out my headlight ( side blinker Is fine ) and bent the hood a lot and it bent up the support beam where the latch is... What it did was bend in the area where the condenser sits and pushed it strait back the condenser fan was done the radiator fan works but isnt pretty.... So I spent until about 3am pulling the frame out as best I could ( now mind you the engine as it was could have started and ran if the radiator was not busted) So I got a new radiator in the car with both new fan's installed and working as of now with good clearance from the engine the damage bent the frame enough that the condenser will not fit in fact on of the radiator studs is about a fingers with out of the hole it should be in but it works as of now and the car is driveable and so I rocked my white bumper for today and original headlight that came with the car the grill was fine and this afternoon I went to the pull and grabbed some parts to get the car working right again for now minus the condenser and the only car in the yard that matched my Mulberry Red Pearl was a cb9 a very I mean very clean car that had been side swiped on the driver's side so I proceed to take the hood off and decided to take the bumper as well test fitted it to make sure it would fit and went on my way. I pulled my white bumper off and the hood and fitted the cb9 bumper and hood on the car and they fit pretty darn good except for some gap on the driver's side.... As odd as it looks * yeah seriously it looks odd but will probably not bother me after a while and when I find a sedan in mulberry I will probably swap that one on but the question I have is that I have is that this is a 90/91 bumper (clear lense blinkers) and I was wondering if there is any way of fitting my 92/93 fog lights onto the bumper because the 90/91 deffently will not fit but the curve below the blinkers may allow for the 92/93 foglights to be installed any idea's on if that could work?
thanks
thanks
