Nice
92accordexpower: Timeline
Originally posted by deevergoteHere is fine. It deserves the attention in OT! It's an inspiration to see that car brought back from the dead so many times, only to get better each time!Maple50175 - you're annoying =P
2011 Update!
Since this post was published, here's an update.
in 2008, I finally bought an H22 transmission for the car from a user of the board to replace my blown f22 transmission. I installed it in my stone driveway, and upon finishing the install, I rolled 10 feet and the transmission seized. I then parked the car and lost my motivation. I eventually brought the car to the shop I rent, put it on jackstands, and there it sat for 2 years... until recently.
Over the last couple months, I stripped most of the interior, modified stock seat brackets onto a pair of Corbeau Forza's, added a 4-point roll cage made by myself (My first one), and some 4 point harnesses. Here's some pictures of the roll cage progress followed by the car as it is today.
I installed another F22 transmission, and the car fired right up when the time came to start it. Some fresh gas and fluids, a new ignitor, an updated tune, and it runs as good as it ever has.
After driving the car for a couple weeks, the only thing I need now is a distributor bushing and seal, since I'm losing some oil through the distributor, and we'll be ready for Auto X'ing fun
What did you do to the motor to get it running after 2 years?
Somebody here has been asking about that......MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
...I saw that. I didn't do much of anything. Smart thing would be to drop some oil down the cylinders before hand, but all I did was change the spark plugs, put a battery in it, start the car. Ignitor went bad after 20 seconds of running, replaced that, good to go. First order of business was drive to the gas station and fill er up with 93 to mix with the few gallons of old gas still in there. Obviously change the oil and coolant after that at some point.
