Dead instrument cluster
    My instrument cluster in my '93 just died overnight. It had all worked fine on friday afternoon, and on saturday morning, almost nothing. The battery light comes on before turning the ignition. Any thoughts about how to troubleshoot this?
    1993 Accord Lemons Race Car, "SpaceEx Starship"
    M2A4 Trans, Cusco 1-way Limited Slip Differential, Stage 2 Clutch and 11lb flywheel. A4 Header, 2" exhaust all the way back, catalyst delete, delta 262 grind, glasspack muffler, PT6 ECU.
    search function
    i'm using it right now to get info on swapping a leaky heater core
    http://i220.photobucket.com/albums/d...82408002-1.jpg
      What’s not working exactly? Speedo, tach, anything work?
        Only the battery light before you start it up works. The rest is dead.
        Oh, and I did search. After paging through scores of search results I found one thread that suggested that fuse 13 in the under dash fusebox might be the culprit. I will check it next time I go to the car. It seems unlikely that it is the fuse since one thing on the cluster does work, the battery light.
          It was a fuse. Nothing to it. Of course I don't know why the fuse blew...
