F22a1 sohc with h23a vetch head
    I have a serious question that no one so far has had an answer for me I have a f22a1 sohc non vetch block and I want to put an h23a vtech(bluetop) head on it how do I do this I want to send the head to get ported and what not and prepare the block for the head . My question is where can I get the blueprints to do so and of course anything is possible but is this possible to be done ? What do I need and what do I have to do to make it work
    The bore is much smaller on the f22, this will really change the quench effectiveness of the H23 head. It might require premium gas even without being high compression. You would get the best performance if you were able to run an 87mm or larger piston with the H head.
    The blueprint is pretty much the H23 head gasket.
    They call this conversion a G22 or G23, so if you look around there are some YouTube videos that are detailed step by step what to modify.
