there out of a b16 head and oil was coming out of that corner or the head its the exhaust side on the number 4 cylinder.
Are these valves burned?
They don't look to be burned. They just look covered in oil and carbon build up. Clean them off and see if you notice any pitting or irregularities in the circumference.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Originally posted by TracieS View Postheres one cleaned up
What did you use to clean them?
What is lapping? The edges look more crispy.**Blk Housed Slut Crew Member #1**
Originally posted by F20A CB7 View PostWhat is lapping? The edges look more crispy.
Valve lapping is basically recreating a perfect matching contour between the valve seat on the cylinder head and the valve itself. This allows for better compression due to a better seal; less/no "valve blowby."
Thanks^
I was lookin at the pics. After clean up I seen knotches and scratches.. now the edges r smooth lookin. Is that the lapping?**Blk Housed Slut Crew Member #1**
Originally posted by TracieS View PostSo I lapped the valves and this is what I got
Or, just take the head to the engine builder and ask for advise.Last edited by oyajicool; 11-09-2012, 10:13 AM.A&P-IA
Did you use a sawsall blade to clean away the carbon?
Im a little worried about all the scratch marks. Hopefully they dont extend high enough up the stem to contact the valve guide. If they did, the guide could wear much faster. Also the scratches give future carbon a better place to cling onto.
In the future, using a chemical solvent soak, or a gentle wire brush is the best way to remove carbon. Much safer to the valve.ON_N20Nitrous = Been there. Turbo = Now. Nitrous + Turbo?... LOADING
Actually, he's right. The picture was somewhat unfocused and I couldn't really tell before. You may want to sand and polish the stems on these to remove those grooves.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Originally posted by oyajicool View PostTo me, contacting surface look too wide and there's no margin at the edge. I would consider consider head work if it was my engine.
Originally posted by ON_N20 View PostDid you use a sawsall blade to clean away the carbon?
In the future, using a chemical solvent soak, or a gentle wire brush is the best way to remove carbon. Much safer to the valve.Originally posted by Jarrett View PostActually, he's right. The picture was somewhat unfocused and I couldn't really tell before. You may want to sand and polish the stems on these to remove those grooves.
Yea and the cleaning was spur the moment souldve soaked them like you said.
And everything turned out ok car has been running smoke and oil leak free for about a week now. And that cylinder had 180 compresion and the others were around 190.
