head swap
    F22B1/2 head, on A1/A4/A6 block. Yes.
    I was going to do this as well! but figured in the end it'd be pointless. Plus, the B heads don't flow as well as the A heads do apparently. I was unaware of this, but wasn't the reason why I didn't go with a head from a CD. I guess if you're going to get the head off, you might as well have swapped for an H23 even...
    life is good.
      An H23 head swap wouldn't be worthwhile either. If you're going to remove the head and spend money, spend money on getting machine work done to the F22A head. You'll see much better gains that way.
        oh well i meant the full engine swap mike lol
        life is good.
          Ah, ok. "I guess if you're going to get the head off, you might as well have swapped for an H23 even..." sounded like you were suggesting the headswap.
            well, i worked from midnight-4 am lmao getting the A6 head off. took a bunch of coors light breaks though...
            anyways, when all was said and done i realized we coulda just swapped an H in probably an hour less!
            i haven't really had one of these engines apart yet, mostly D series.
            life is good.
              Originally posted by jerry18849 View Post
              ok so what is another way to get more power out of my f22a without intake or exhaust components? (cold air intake, headers)
              Well it's kinda pointless to do other mods with out doing the big 3 first (intake, header, exaughst). I can tell you that header and exaughst will definatly make your car much more fun to drive. And it will also allow your motor to breath a lil better to get it ready for other upgrades.
              I gusse the next step after those would be mild cam, port n polish and a tune.
              My System
              http://www.cb7tuner.com/vbb/showthread.php?t=165155
