Old 10-24-2014, 08:50 PM   #1201
Raf99
wow, i was actually nominated for September AOM,........... and lost again.
Thanks to the person who nominated me, but it comes down to how many friends ya have on this site. They really need to get rid of that IMO.
Old 10-25-2014, 07:07 PM   #1202
Maple50175
Gigity Gigity
Location: Good ol' Ma. Does it look like im kidding assholes! XM-BPM for life!
Maple50175 is cool... so far.
Send a message via AIM to Maple50175 Send a message via Yahoo to Maple50175
Nice car sir.
Maple50175 is offline   Reply With Quote
Old 10-26-2014, 11:08 AM   #1203
Raf99
Originally Posted by Maple50175 View Post
Nice car sir.
Thank you sir
Old 10-26-2014, 07:42 PM   #1204
Raf99
So working on the car again today, good times! Today was ....
- Find a spot for the fuse box
- Install the front speaker pods
- Route all wiring for speaker pods, splitters, tweeters, amps
- Check out rear end squeaks and clunnks
Below is a diagram of the general setup of the amps and speakers. The wires do not run this way and i left out the data wires.
The large amp (amp1) powers the subs. The smaller amp (amp2) powers the 300W Type R front pods. (the stereo powers the OEM speakers). There is a splitter off the battery for two wires. 1- A 2AWG wire runs to a 160amp circuit breaker and then to the start. 2- A 4AWG wire runs to a distribution block which powers both amps.
I'm debating if the amps need a in-line fuse since they have a built in fuse themselves. Any ideas guys?
And although the car had these coilovers installed by a professional mechanic I still found loose bolts. The drivers side bolt was not tightened on the top of the coilover and other things. Because of this the top of the super streets drivers side coilover was rubbing against the metal piece that sits near the seatbelt. So I just removed these things, I'm not sure what the purpose of these were anyways.
Old 10-28-2014, 08:24 PM   #1205
Raf99
Some quiet in here.........
But i'll just keep going with the random pics
Does anyone know what the bolt holes are for seen in this pic? I always wondered this.
Old 10-28-2014, 09:17 PM   #1206
wildBill83
wildBill83 seems to have made some friends!
seems to be bolt holes for the factory disc changer. I had one in my CB7 when I first got it.
wildBill83 is offline   Reply With Quote
Old 10-28-2014, 10:25 PM   #1207
sonikaccord
Yes!!! The in-line fuse is NOT to protect the amp, rather it protects the wire from burning your car to the ground. Install it as close as possible to the battery. Pick the fuse size based on wire gauge.
Old 10-29-2014, 05:08 AM   #1208
Raf99
Well you made my day. Always wondered this. One could make a nice shelf for an amp utilizing these bolt holes.
ya... I know I know Just figured there was no way on such a short run. 4AWG wire running to a 1000W amp with 80amp fuse and 4AWG wire running to an amp with 30amp fuse. Luckily I have some in-line fuses I can use.
Old 10-29-2014, 06:28 AM   #1209
sonikaccord
Wait, I spy a circuit breaker? Why not use that?
Old 10-29-2014, 05:27 PM   #1210
Raf99
Circuit breaker is 160amp for the 2AWG wire running to the starter. I'll use two in-line fuses on the wires running to each amp.
OR....... can i use one in-line fuse running to the distribution block for the amps. I'm thinking I should use two separate in-line fuses for each amp as one amp has a 80amp fuse and the other a 30amp fuse.
What's the fuse rating to use for a 4AWG wire?
Old 10-29-2014, 06:35 PM   #1211
Lucien
Lucien is cool... so far.
Send a message via AIM to Lucien
Did you get the fenders on yet? I cant wait to see how they look.
Lucien is offline   Reply With Quote
Old 10-29-2014, 07:01 PM   #1212
Raf99
Actually I just bought a buffer the other night and buffed them last night.
I may put them on soon if I can find the time. II'm also moving in 15 days which is going to put a hold on everything.
Old 10-29-2014, 07:05 PM   #1213
sonikaccord
4 awg is rated to about 100A, +/- some amps.
You can use one fuse as long as all of the wire is the same size.
If you use a smaller inline fuse than your amps rated fuse, then the smaller fuse becomes the amps protective fuse if you wanted to go about it that way.
Old 10-29-2014, 07:34 PM   #1214
Raf99
Yep. Going to use same fuse that each amp has. Two in line fuses.
Old 10-29-2014, 08:46 PM   #1215
Raf99
I appreciate the support sonikaccord. You should come by more often
Tonight's work.....
Only thing left to do is wire up the backup camera power and ground. I figured I'm going to wire this to one of the amps since they have a +12V / ground and since they only come on when the car is turned on.
Old 10-30-2014, 08:52 AM   #1216
kratemertyl
kratemertyl is cool... so far.
What's the idea behind the circuit breaker for the starter? Is it a must?
kratemertyl is offline   Reply With Quote
Old 10-30-2014, 12:16 PM   #1217
Raf99
It is the most important must of the battery relocation! If the wire between the starter and the battery were to fray/touch the body/malfunction it would simply keep sparking sending electricity out of the wire and catch the car on fire. The breaker is there to cutoff the flow of electricity to that wire/component.
Old 10-30-2014, 07:43 PM   #1218
Raf99
If ya'll remember this..
Finally hooked up, turned out great!
Old 10-30-2014, 10:21 PM   #1219
kratemertyl
I got ya. I imagine circuit breakers have different ratings, what are you running ? And how about placement, as close to battery as possible I guess huh
Oh and I dig the new signature pic
Old 10-30-2014, 11:13 PM   #1220
Lucien
Wow. Where is that tailight from?
