Old 03-20-2012, 09:57 PM   #1
TracieS
TracieS seems to have made some friends! TracieS seems to have made some friends!
F20b swap revs to redline by itself.
So I did my swap got it running its not throwing any CEL's. But when you start the car it automatically revs all the way up I turn the car before it gets to high. Its like the throttle is hung open but it isnt. I changed the throttle body thinking it was the TPS and still the same thing. I tried to Google this and all I get is what is stock redline of the engine. SO any help is appreciated.
STANCE|WORKS
TracieS is offline   Reply With Quote
Old 03-20-2012, 10:00 PM   #2
dj_ender
Mod\Dubstep Pusher
I guess the obvious suspects are a stuck open butterfly in the intake, or your throttle cable is too tight. Did you read the setting on both TPS's?
Old 03-20-2012, 10:03 PM   #3
TracieS
The butterfly is closed and no I didnt check the tps on the other one it was pulled off my buddy's running car. And then put it back on his car and it worked on his car again.
STANCE|WORKS
Old 03-20-2012, 10:07 PM   #4
dj_ender
Mod\Dubstep Pusher
What about the throttle cable?
Wait, are you sure you didn't mix up the TPS and MAP plugs?
Old 03-20-2012, 10:14 PM   #5
TracieS
I mean I can check it tomorrow but I dont think its tight and its not pulling on the wheel to turn the butter fly. And from the inside of the car the pedal feels fine. I may just unhook it and start it that wya and see what happens.
Map is hooked up behind the dash and pluged up in there I never even unplugged it.. I deleted the emission on my car.
STANCE|WORKS
Old 03-20-2012, 10:17 PM   #6
dj_ender
Mod\Dubstep Pusher
Also, did you reuse the CB harness, or make your own/mod the CB one?
Old 03-20-2012, 10:19 PM   #7
TracieS
Its a stock uncut cb harness I haven't tucked my bay yet just so I can work out all the bugs then once it done it going to be tucked.
STANCE|WORKS
Old 03-20-2012, 10:23 PM   #8
dj_ender
Mod\Dubstep Pusher
Damn, there's not a whole lot of things that can control the gas. Only other thing i can think of is the set screw under the rotor is screwed in too far. what happens if your try starting the car without the TPS plugged in? And are you using a chipped ECU or an OEM one?
Old 03-20-2012, 10:29 PM   #9
TracieS
Same thing starting it unpluged revs right up. I can check set screw tomorrow to. Thats why I made this thread I am at a lost and I am usually really good at figure out what is wrong cars.
STANCE|WORKS
Old 03-20-2012, 10:31 PM   #10
markrutherford
markrutherford is cool... so far.
The stock redline is 8200-8500 rpm depending where you look. Ive taken mine to 8500 with no issues. But did you replace the f20b intake manifold and injectors with h22a1 parts like I said?
Bought from:AbsurdNY,92smokeaccord,cb7inct,nevi325,xkjnboix,cb 7resurrector,JoshM
MRT: http://www.cb7tuner.com/vbb/showthread.php?t=203451
markrutherford is offline   Reply With Quote
Old 03-20-2012, 10:33 PM   #11
TracieS
Yea I put a h22 IM and injectors on it today. Im running a p13 ecu to.
STANCE|WORKS
Old 03-20-2012, 10:33 PM   #12
dj_ender
Mod\Dubstep Pusher
same Thing Starting It Unpluged Revs Right Up. I Can Check Set Screw Tomorrow To. Thats Why I Made This Thread I Am At A Lost And I Am Usually Really Good At Figure Out What Is Wrong Cars.
Ecu?
Never mind...
Old 03-20-2012, 10:41 PM   #13
markrutherford
Dont use a p13 with the f20b. it will run like crap! That might be your issue right there. Just wait till you get the chipped ecu from drummersteve.
Old 03-20-2012, 11:09 PM   #14
tm123
tm123 is cool... so far.
yeahh check the idle set screw
see if someone has messed with it
if they havent the paint should still be on the head of it.
someone had the one all way out on my h23 IM.
i just snugged it back down and then a half screw to the left
-Tyler
tm123 is offline   Reply With Quote
Old 03-20-2012, 11:19 PM   #15
dj_ender
Mod\Dubstep Pusher
I was originally thinking the TPS wires got switched around, that's why i asked if it was a modded harness. I wonder if the pin outs are different on the P13 than the PCB....
Old 03-20-2012, 11:34 PM   #16
GhostAccord
The stock Honda ECUs have a vacuum leak fuel cut... it's activated when the manifold air pressure rises and the TPS % doesn't change, or is below a certain %. That's why most people get that idle surge when the IACV is bad or they have a vacuum leak. If the ECU didn't have this cut the engine would rev as high as it could with the amount of air leaking in.
Do you have another ECU that you can try? It would be helpful if you have a chipped ECU that you could monitor the Sensor signals.
MR Thread
GhostAccord 2.4L Blog
by Chappy, on Flickr
Old 03-20-2012, 11:43 PM   #17
evil_demon_01
Moderator
evil_demon_01 is someone to admire evil_demon_01 is someone to admire evil_demon_01 is someone to admire evil_demon_01 is someone to admire
Does that apply to all Honda ecu's?
Because a 96-98 CRV will rev sky high if you leave the intake resonator off.
The only way that the engine can rev up is if enough air is getting in.
If the throttle plate is closed, then it cannot rev up.
OP - Are you sure the brake booster is connected? And that the gaskets are OK? - Specifically the intake to head gasket.
My 5.7 LS1 Holden Ute
evil_demon_01 is offline   Reply With Quote
Old 03-20-2012, 11:52 PM   #18
GhostAccord
I have never seen that before. The ECU's that I have worked around have had it. That's why they surge if you unplug a vacuum hose. I have never seen an engine surge just because you remove the intake resonator, unless it has a vacuum hose that you opened to the air. Then again I have never worked on a CRV. I'll have to try it on my buddies this weekend and see what I can find out by hooking it up to the scanner.
And the engine can rev up with the throttle plate closed, the air could be coming in from any number of other possible openings. An unplugged hose, any of the gaskets leaking, from the throttle body down to the injector o rings. If the EGR plate isn't sealed or the IACV gaskets toast causing a leak....there are numerous places for air to get into the intake other than the throttle plate.
MR Thread
Old 03-21-2012, 12:18 AM   #19
evil_demon_01
Moderator
CRV intake resonator is part of the intake manifold (it sits on top of it)
That was my point - If the throttle is closed then there HAS to be a leak somewhere else.
Hence why I said check the booster hose and intake gasket.
Old 03-21-2012, 05:40 AM   #20
TracieS
Ok thanks for the info guys. Ill go over all the intake bolts again today and make sure there tight. Ill let yall know what I find out.
STANCE|WORKS
