Go Back   CB7Tuner Forums > 4th Gen-eral > Other Automotive > Other Automotive Members Rides
Old 06-30-2014, 03:52 PM   #21
'93CB7Ex
Foundation Member
did you even get it running yet?
COUPE K24
Old 06-30-2014, 08:33 PM   #22
TracieS
TracieS seems to have made some friends! TracieS seems to have made some friends!
Yea but never had a exhaust put on it because we are going to boost so I didnt want to waste the money.
Got the battery tray out moved the turbuo so it clears everything happy with postioning going the start building the hot side tomorrow and working on cutting up the passanger header and making a log manifold picked up some 15x10/8 centerline wheels going to run some mickey et streeet radial for some dig and roll action
STANCE|WORKS
TracieS is offline   Reply With Quote
Old 06-30-2014, 08:49 PM   #23
TracieS
thread was missing things
little brother doing somhing
Harness came still need a fuel pump
LSx s10 - YouTube
STANCE|WORKS
Old 07-28-2014, 12:42 AM   #24
crazymikey
crazymikey is very helpful crazymikey is very helpful
Jesus. Every time I come back you're working on some crazy new project.
This thing is bad ass! Keep it up, I'm always interested in what you're building.
crazymikey is offline   Reply With Quote
Old 09-16-2014, 07:51 PM   #25
TracieS
Got tge truck back together running it na with a 125 shot right now till this winter then ill throw on the turbo put on some 24x12.5 et streets these things grip to priba try to make it to gage performance some ri e soon to get a dyno tune
STANCE|WORKS
Old 09-17-2014, 09:47 AM   #26
trickedaccord92
trickedaccord92 is cool... so far.
Send a message via AIM to trickedaccord92 Send a message via Yahoo to trickedaccord92
Sweet build bro! I just got an 83 1st gen s10 last month also. Won't be getting into the motor swap until tax time though. How much have you got invested in the motor swap so far? I should have around $5k to dump into mine come tax time.
trickedaccord92 is offline   Reply With Quote
Old 09-17-2014, 11:25 AM   #27
wildBill83
wildBill83 seems to have made some friends!
Nice work. I picked up an 89 s10 blazer a couple of months ago. Your goal is low and fast mine is torque, 31" tires, and a moderate lift. Can you take a picture of your ground clearance?
wildBill83 is offline   Reply With Quote
Old 09-17-2014, 10:40 PM   #28
TracieS
Quick ball park figure about 38 to 42 with a quick add up of all the big things I can remember it will add up quick but if you know where to get parts and what works with what you can save a ton
Thanks and yea I can snap some tomorrow
STANCE|WORKS
Old 09-18-2014, 12:05 PM   #29
trickedaccord92
What are your plans for the rear end and axle? Obviously the stock ones won't hold up with the power you are planning to lay down with the turbo setup. Also are you re enforcing the frame to keep it from twisting?
Old 09-18-2014, 01:10 PM   #30
TracieS
Right now just going to use a 8.8 till I get the currie 9in kit and it might get a cage but I doubt it's a street car mostly roll racing and some digs on the street I will only run about 7 or so on the street and be fine and turn it up if needed
STANCE|WORKS
