dreamability : 1993 Accord EX
    ENGINE / EXHAUST: ٩(◕‿◕)۶
    Stock F22A6
    DC Sports header
    2.25 inch piping
    Magnaflow 3" dual tip oval
    Magnaflow Cat
    All aluminum radiator
    EGR delete
    Oil catch can.
    Sikky thermo insulating intake gasket
    Head rebuilt with new springs, retainers, guides
    Gatorback timing belt
    Genuine Honda OEM Timing Belt Tensioner
    Gates water-pump and thermostat
    NGK plugs, wires, and coil
    All seals replaced; main rear, oil pump, cam, crank, dizzy, oil pan, balance shafts
    Dizzy, Starter, & Power steering pump rebuilt.
    Exedy Clutch and pressure plate.
    12 pound flywheel
    Genuine Honda OEM throw-out bearing
    Bay has been tucked, sprayed with 2k epoxy primer, frost white base-coat, and 2k clear
    EXTERIOR: °˖✧◝(⁰▿⁰)◜✧˖°
    Flush mount spoiler, (OEM style)
    92-93 sedan trunk.
    5th Gen Accord Type R style lip
    All clear taillights, blacked out with LED's
    OEM Fog-lights
    Blacked out headlights with yellow high-beams
    Front fender side markers
    INTERIOR: \(^▽^)/
    Forever Sharp riveted mahogany steering wheel
    Custom made pine shift knob
    Aluminium gauge trim set
    SUSPENSION / WHEELS: ଘ(੭ˊᵕˋ)੭* ੈ✩‧₊˚
    Watanabe Style Wheels 16X8 +40 offset,(purchase from King of Rims in Malaysia
    Koni Red Suspension Kit, (these are new old stock), with
    Vogtland springs (1.8") and adjustable Koni reds (up to 1")
    DC Sports shock tower bar, (new old stock)
    Moog front upper control arms, tie rods and ball joints.
    AUDIO/ELECTRONICS: (◕‿◕✿)
    Full wire tuck
    Fuse box relocation
    Battery relocation with 200 amp circuit breaker
    1/0 AWG cables
    1200 watt x4 amp
    7" touchscreen head
    JBL speakers
    FUTURE PLANS: o( ❛ᴗ❛ )o
    Slow and Steady.
    Get it on the road before the end of summer 2019
    Make my own fiberglass rear window visor.
    Make a decision on future Engine and tranny.
    °˖✧◝(⁰▿⁰)◜✧˖°
    I bought my 93 coupe in October 2017.
    In May 2018 I pulled it into the garage to install Some Koni shocks with Vogtland springs as well as some watanabe style wheels and just kept going, lol.
    I’ll do my best to document what I’ve done the last 12 months.
    It would be great to have some feedback or help as I progress, and hopefully it may prove helpful to someone else down the line.
    Wish I’d done this from the start because I could have used some insight more than once.
    Also, I can't see doing this without the CB7tuner community. It has been an indispensable resource. Thanks!
    I did an ABS delete.
    I've also done a full wire tuck, fuse box & battery relocation.
    Here is a DIY I made of the process
    http://www.cb7tuner.com/vbb/showthread.php?t=210829
    The night before I pulled it into the garage
    Day One
    Some of the first work I did was to the suspension, brakes, bearings, and bushings.
    Before
    After
    Front bumper was pretty much beyond saving. They had cut the fog lights holes way to big as well.
    New bumper. I carefully cut new holes for the fog lights and ready for paint.
    The finished product.
    Engine removal day.
    Transmission was hell to clean! Just some minor oil leaks, lol.
    ABS Delete, wire tuck, fuse box relocation to glove box, and battery to trunk.
    I extended, soldered, and heatshrinked all wires.
    I also made my own block off plate.
    If you'd like to see the wire tuck I made a DIY:
    For the battery relocation I used 1/0 AWG cables and soldered on copper lugs.
    I Made my own battery box. Its lined with truck bed liner, finished outside with outdoor polyurethane.
    I vented it under the car through the frame and used weather stripping around the lid with wing nuts to hold a seal.
    On the side of it I placed my junction box and circuit breaker.
    The head ready to go back on. Engine had all oil seals replaced, cleaned and painted as well as the intake and plenum. Power steering ,dizzy, and starter are rebuilt. Dizzy and pump polished.
    Unwrapped, cleaned, redirected and re wrapped the engine harness.
    Epoxy primer, base coat, and clear coat on the bay, underside of hood, flush mount spoiler, and trunk.
    The all-clear taillights will be tinted black with LED lighting
    I spent a lot of time on the graphics. I made them in Adobe Illustrator.
    Then I had to find someone with a good enough vinyl cutting machine to cut something this detailed.
    So after the white base coat I applied the decal then the turquoise base coat, removed the decal and lastly applied my clear.
    Getting them all off between the second base coat and clear was difficult, but think it turned out pretty good.
    Just finished the painting today. I had to redo the trunk and flush mount spoiler because I ran out of clear and didn't have enough left to get it to flow. Looked gritty.
    Also started on the second radiator retaining bracket. Decided to make my own out of plate aluminum. Going OK, just a lot of hand filing.
    Thanks for checking out my work.
    I will keep posting my progress.
    My YouTube channel
    https://www.youtube.com/channel/UCWG...y6tJ7wJMI4J8vA
    Instagram
    https://www.instagram.com/dreamability71/
    Members Ride.
    http://www.cb7tuner.com/vbb/showthread.php?t=210942
    This is some really nice progress. I love it. I like the color you used for the trans and engine block. What color is that?
    ~Mark~
      NH-503P-3, Thanks man! Its VHT Cast Iron. Yeah I love it too. Cant really see in the pics but it has some nice flake in it.
      My YouTube channel
      Instagram
      Members Ride.
        Looking great! Glad you finally got an MRT up and going.
        When does the engine go in?
          Thanks Jerrett. Yeah finally got something on the MRT. I should be dropping the engine in the next couple weeks. Have some projects for my boss going next couple weekends, so hopefully after that.
          My YouTube channel
          Instagram
          Members Ride.
            Man that is one clean engine. Love all the work so far. Looking forward to more updates to come.
            ~Nick~
              Good job so far man. It's coming together. I love that wiring. About that DC header, how well does it fit?
              My '91 LX build. Bought September 2017. Sold June 2020.
              http://www.cb7tuner.com/vbb/showthre...r /> t=209871
                Wow, man! I've gotta hand it to you, that is some really nice work. The attention to cleanliness and detail is awesome. Thanks for getting it all together to post on here.
                *** Think of others before thinking of yourself. ***
                MRT
                Selling on Ebay!
                15.10 @ 90.42mph
                Current fastest Laguna Seca Lap: 1:52.889
                  Thanks man! I will be sure to post any new progress. Happy I get to share my work.
                  Hey man. Yeah, whatever wiring will be seen has gotta look clean!
                  As far as the DC header, fitment is perfect, including clearance for the AC lines. I checked them tonight so I could let you know. Model is HHC5016.
                  Haven't seen anything on your thread sense you did the seats. I'll be keeping an eye out for anything new.
                  Thanks, I really appreciate it!
                  Yeah, nothing gets a pass till its been cleaned, polished, rebuilt, or replaced.
                  Even the bolts and screws are polished, Lol .
                  I'm glad I finally got a thread up and going. Now I just have to keep up with it!
                  My YouTube channel
                  Instagram
                  Members Ride.
                    I've gotten the flush mount spoiler all lined up and holes drilled for the two corner mounts. Perfect fit.
                    Now I just have to wait for the 3M Automotive Acrylic Plus Attachment Tape to arrive.
                    Decided to go with this instead of the molding tape for something a little stronger and more permanent.
                    My YouTube channel
                    Instagram
                    Members Ride.
                      Heyyy! Nice build! Amazing ✌️👌👏
                      My Ride Thread
                      The fear of death follows from the fear of life. A man who lives fully is prepared to die at any time.
                      Mark Twain
                      FaceBook
                        Cool! Another cb enthusiast from the Dallas area! There's not many of us left around here lol but dang looking good.. when you get it up and running you should bring it out to the meets.. keep up the good work
                          Originally posted by DragonEye View Post
                          Heyyy! Nice build! Amazing ✌️����
                          Thanks Man, really appreciate the props!
                          Man I'm glad to hear from some other CB owners in Texas. You in Dallas? I'll definitely be bringing her to some meets. Plan on being at the Import Face Off in Ennis, Tx. this winter,(11-03-2019). Other than that I don't know of any around Dallas. What meets you talking about? I'm for sure down to show when I get her done! Should be rolling in next 2-4 months.
                          My YouTube channel
                          Instagram
                          Members Ride.
                            Hot damn, that's a fine looking build so far. I really like what you did with the artwork on the valve cover and intake manifold. Really looking forward to see where you take it.
                              Thanks Man. I really appreciate the feedback. Should be moving along on it the next couple months and giving more updates.
                              My YouTube channel
                              Instagram
                              Members Ride.
