Old 10-25-2017, 11:47 PM   #1
zedjr10
zedjr10 may have said something they shouldn't have...
remove pitting from oem dull alloy type rims
Whats the best way to remove pitting from the oem dull finish alloy rims. Never done this before so don't know. Have read use steel wool and some vinegar. Is this the same with the dull alloy finish?
Old 10-26-2017, 11:07 AM   #2
wtfisafleek
If it's truly pitted you'd have to either fill in the pits or cut down the present finish. You may just be able to wetsand with a high grit and then use some compound to bring some luster back so the pits aren't as noticeable. I did this on my wheels and the results were fanastic. I used 800 grit sandpaper with the water hose attachment set to mist, and once I'd rubbed down everything real well with that, I switched to the Mother's Powerball (the one with the long stem) stuck in my drill and Meguiar's Ultimate Compound. Then I buffed it off with a towel afterward.
Old 10-26-2017, 11:19 AM   #3
Bunta
Bunta is cool... so far.
You did your center caps using the same method?
Old 10-26-2017, 09:04 PM   #4
wtfisafleek
No I didn't touch those. They were already pretty clean.
Old 10-27-2017, 02:52 PM   #5
zedjr10
Those look clean clean clean. Was there a dull alloy finish rims for 92 ex models. Mine and some others i've seen have a dull finish it seems stock. Is this right or did my alloy finish just get dull looking over time?
Old 10-27-2017, 03:35 PM   #6
fleetw00d
The dull finish is age. OEM was shiny like these that I had refinished:
What they look like on the car shows up better in the MRT for Ruby (90 LX)
90 LX 4dr 5 spd 385,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
07 Element EX AWD 192,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210623
07 Element EX AWD AT (2) 87,000 - MRT: www.cb7tuner.com/vbb/showthread.php?t=211920
LOTS of CB7 parts - ENTIRE COLLECTION - FREE
Come and get it.
http://www.cb7tuner.com/vbb/showthread.php?t=192583 or watch for banner ad at upper right
Old 10-29-2017, 12:44 AM   #7
zedjr10
What process you use to get it looking that good.
Old 10-29-2017, 07:58 PM   #8
zedjr10
Did you start with 800 grit? Anything else you do to get that shiny finish. Does it really look that good in person?
Old 10-29-2017, 10:49 PM   #9
fleetw00d
I used RimWorks in Dayton, Ohio. They grit blast the wheels, powder coat the color between the spokes and the back of the wheel; remachine the face, then powder coat clear. $125 per wheel, but they look brand new.
Come and get it.
Old 10-30-2017, 05:28 PM   #10
zedjr10
I used RimWorks in Dayton, Ohio. They grit blast the wheels, powder coat the color between the spokes and the back of the wheel; remachine the face, the powder coat clear. $125 per wheel, but they look brand new.
I want to do it on the cheap if i can or i will wait till i can justify spending $500 on cleaning them. I definitely want to keep the oem wheels. I got alot of pitting on the inside parts.
Old 10-31-2017, 06:39 PM   #11
fleetw00d
Just requires a lot of elbow grease. I've used the process described by wtfisafleek. I used the car as a lathe to spin the wheel while I used a sanding block and progressively finer grits to smooth the edge and face while trickling water on it. I have used an 80 grit Scotchbrite disc to smooth out curb rash on the outer edge.
On a set of aftermarket wheels I managed to remove the corrosion and polish the outer lip: http://www.cb7tuner.com/vbb/showpost...4&postcount=24
Old 10-31-2017, 08:59 PM   #12
wtfisafleek
Those sound great, got any pics?
Do it! It's just a car payment...
Old 11-02-2017, 10:01 PM   #13
fleetw00d
The picture in my post above shows a wheel that was refinished by RimWorks; like I said, they show up better in the photos in my MRT and the "Rescuing Ruby" thread.
Old 06-02-2019, 08:09 PM   #14
zedjr10
Do you think my clear coat is still on rims. Wouldn't sanding the rims show it as it would peel off. I am about to do my rims or at least try. I am trying to cut down on any costs or steps. I have sanded them down some with 80 and 160 and never seen anything like a clear coat come off. Realized this is too much work to go all the way to mirror like finish by hand. 5 inch orbital sander only gets half of the rim. I am also think of buying this nice 3 inch mini polisher or a 7 inch polisher. Am just wondering is it small enough to get the rest or close to it.
Old 06-02-2019, 09:38 PM   #15
fleetw00d
It is usually pretty obvious if the clear is still there or not. Any of the techniques above will pretty much require you to sand off/through the clear coat to be able to clean up the aluminum. Once you have them cleaned up, you could potentially find a local powder coater to do them in clear, or get some clear wheel paint to try to preserve the finish.
Old 06-03-2019, 03:32 PM   #16
zedjr10
What you think about using a 3 inch polisher on them. Was going to use that to sand them with also. Then use same polisher to make my paint shine. I got the 6 spoked ex wheels.
Old 06-07-2019, 09:42 PM   #17
fleetw00d
Use whatever works. Here is a another post describing how I cleaned up a set of 12 spokes: http://www.cb7tuner.com/vbb/showthread.php?t=189546
Old 06-08-2019, 10:28 AM   #18
zedjr10
Am doing first rim today. How are the rims orignially done oem. As there is something definitely underneath. A clear coat or paint. I think a silverish paint is done on some. After putting some stripper on i see this stuff coming off on the parts where the valve stem is. The outer flat part had a clear coat on it. All that sanding and all i was doing was sanding paint and clear coat i think.
Old 06-08-2019, 10:44 AM   #19
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
There is silver paint between the spokes, and clearcoat across the face.
Old 06-08-2019, 12:41 PM   #20
zedjr10
THanks. That what it looks like. The paint stripper i got has a very hard time in getting that silver paint off. I need to go find some aircraft paint stripper i think. The clear coat am not sure if is still there or gone.Maybe the past sanding has removed most of it cause i see nothing like a clear coat coming up.
