#1 |
Gold Member
Where is parking brake light wire for remote start on manual
I am in process of wiring up the remote start on my 5-speed. I need the parking brake light wire from one of those harness near fuse box or whatever harness it is on. All the wiring diagrams do not show this as on automatic it is not needed. Anyone know this info?
#2 |
Contributing Member
Center console, at the base of the ebrake handle you should see a little wire. Simply tap into that and run the wire to the brain.
#3 |
Gold Member
it is the green/red wire in case anyone is wondering. There is no harness it goes to it seems. It is a ground at e-brake switch when pulled and posi goes to dash light. I haven't actually confirmed this as i will hook up this and clutch switch this weekend.
Thread Tools | |
Display Modes | Rate This Thread |
