Old 03-31-2010, 12:04 AM   #1
swk_cb7
swk_cb7 is cool... so far.
stupid side mirrors!!!!
ok i fixed all the small fuse problems,but now i have a mirror problem!!!
When i switch to the lft r rht mirror it instantly goes down w/o control. i can adjust it very slightly out(1cm or so) with the switch before it stops. What could be the problem?:confused:
swk_cb7 is offline   Reply With Quote
Old 03-31-2010, 12:08 AM   #2
noobcake
noobcake seems to have made some friends!
mine do it to.
i think its common. i just dont move the switch
noobcake is offline   Reply With Quote
Old 03-31-2010, 10:35 AM   #3
omarlee
omarlee is cool... so far.
have no clue
omarlee is offline   Reply With Quote
Old 03-31-2010, 10:59 AM   #4
lxinks
lxinks is cool... so far.
Mine did the same thing i replaced the switch but it still didi it so i quit using the switch problem solved
h23a3 lxinks
lxinks is offline   Reply With Quote
Old 03-31-2010, 11:50 AM   #5
AstroVannin
AstroVannin is cool... so far.
Mine was the switch itself... changed it. Problem solved.
Members Ride Thread - http://www.cb7tuner.com/vbb/showthread.php?t=121452
Originally Posted by slammed4thgen View Post
dustin, you are a dick!
officially the lowest ive seen now
AstroVannin is offline   Reply With Quote
Old 04-01-2010, 10:10 AM   #6
swk_cb7
ok well i think i might go to a pull-a-part and get the switch. if it doestn't work o well!!!
Thankx guys
Old 04-01-2010, 10:15 AM   #7
Hondateck2010
Hondateck2010 is cool... so far.
Send a message via AIM to Hondateck2010 Send a message via MSN to Hondateck2010 Send a message via Yahoo to Hondateck2010 Send a message via Skype™ to Hondateck2010
check the cables and make sure there' not touching and I think theres a relay box that can get changed. also you can rebuilt your switch, its not hard at all
Links to my rides :
1992 Accord EX*
1990 Accord EX
1991 Accord SE (4th)
1991 Accord SE (3rd)
1991 Accord SE (2ND)
1991 Accord SE
Hondateck2010 is offline   Reply With Quote
Old 04-01-2010, 10:20 AM   #8
MikeW
Master Of Posting Nothing
MikeW has a HUGE cock! MikeW has a HUGE cock! MikeW has a HUGE cock! MikeW has a HUGE cock! MikeW has a HUGE cock!
Send a message via Yahoo to MikeW
I took my old switch apart and lubed up all the contacts with vaseline. Worked good for a while. Got a new switch and they work fine now.
KeepinItClean | EnviousFilms | NoBigDeal | YET2BSCENE | . ` ' / . | click here.
Originally Posted by Jarrett View Post
MikeW is offline   Reply With Quote
Old 04-01-2010, 10:42 AM   #9
bcjammerx
bcjammerx seems to have made some friends!
Send a message via AIM to bcjammerx Send a message via Yahoo to bcjammerx
check the wiring diagram it's on page 12-29 (E-52) of the haynes manual
...for DC motors like these, usually the power flows one way to go up, then reverses the power for down...same with window motors. The switch just swaps which way the power flows through the motor.
It sounds like you have a short somewhere, whatever direction it goes, check that circuit.
____
bcjammerx is offline   Reply With Quote
Old 04-09-2010, 04:25 PM   #10
swk_cb7
honestly, i think om going to just leave it That sound like too much just for the mirror switches. i know from pass expriences electrical shorts can be and requires beer+patience thanx anyway i mean it seems like alot of the other guys have to same problem and just lefted it.
mirror , problem , side mirrors
