whats up peeps been having a problem with cel #7 TPS. maybe someone can tell me what im doing wrong. one day a while back i got a cell and i checked it. turned out to be #7 TPS. as per the haynes manual, i did the voltage check on the connector, two outer terminals i had 5volts. next i took off the throttle body and read ohms on the outer terminal and the middle terminal. all were within specs. put every thing back together and tried to adjust it as per the instructions from Ghost accord here couldnt get a voltage at all on the red black wire. what would be the next step?? im stuck...car drives ok but dont like driving with a CEL might mess something else up. also checked continuity from TPS connector to driverside connector on the shock tower. please help!!!
TPS Problems adjusting
Ride List
1990 Accord dx coupe - my baby (dsm turbo set up in progress) http://www.cardomain.com/ride/3202853
2005 Mazda 6s - daily driver http://www.cardomain.com/ride/3171724(totaled)
newest 2006 mazdaspeed 6 http://www.cardomain.com/ride/4073987/2006-mazda-mazda6Tags: None
Sounds like the TPS is bad. You were referencing the Red/Black (sensor signal) wire to the Green/White (sensor ground/reference), correct? It should give a readout of some sort, but if it's sporadic or doesn't behave the way it should, it could be the TPS is broken, or the wire/connector has an open circuit
Hmm, silly Q. Did you have the key turned to ACC when measuring the volts with everything connected?
And to confirm somethings.
On the TPS sensor
- You shold get less than 1000ohms on closed throttle
- You should get 3K to 6K when throttle is open, varying
- With key to ACC the TPS wires should get 5V and less than 5V when throttle is opening.
It sounds like your key wasn't on, or the TPS sensor is stopping the current dead.
Yeah key on acc whoLe time. All the checks checked out. When I have time ill do everything again From scratch. I tried 3 diff tps sensors, All same result. one was brand new.
Ride List
Originally posted by blazenem View PostYeah key on acc whoLe time. All the checks checked out. When I have time ill do everything again From scratch. I tried 3 diff tps sensors, All same result. one was brand new.
If you couldn't get a voltage on the red/black wire, you may have an open connection.. Did you check all pins of the TPS? A new one shouldn't go bad but things happen. You may have to do some wire tracing.
EDIT: Check your actual harness pins and make sure they are making contactLast edited by sonikaccord; 01-22-2014, 05:06 PM.
over the weekend when im off work ill trouble shoot it again worst comes to worst i have some ecu pins ill repin the connector and run my own wires then i will know if the wiring is bad...
Ride List
