Old 06-18-2008, 12:55 PM   #1
<1990Accord>
<1990Accord> is cool... so far.
Problem with Throttle
Well today i figured out my high idle problem. it is that when i take my foot off of the gas the pedal doesn't quite come out all of the way which makes it accelerate really slow or make it idle at like 1500 when the engine is warm. I'm wondering does this have to do with the throttle cable being to tight or is there like a spring or something in there that makes the pedal come back that is
worn.
<1990Accord> is offline   Reply With Quote
Old 06-18-2008, 02:50 PM   #2
customchord
customchord is cool... so far.
I would take the throttle cable of the Throttle body and work the butterfly manually. Then is that doesn't stick work the throttle cable and gas pedal to see if it gets stuck. It can only be so many things you just have to trouble shoot to see what part is failing.
-1991 Honda Accord LX H22a-
customchord is offline   Reply With Quote
Old 06-18-2008, 05:10 PM   #3
<1990Accord>
Ok thanks
Old 06-21-2008, 02:30 AM   #4
lilviper97
lilviper97 is cool... so far.
Chances are, it's a bad throttle cable. Stupid, I know, but is the floor mat getting in the way?
lilviper97 is offline   Reply With Quote
