Rosewood
Quashish : 1992 Accord EX
Thats what I thought thanks
C-3PO's MRT USDM yo!
Ive never been able to find it I know out should be on the inside of the door
And sweet let me sees em when you find a good spot
Ps. I kinda want this to go to page 2 so I don't have to scroll through all my pictures lol
NICE LOOKIN ROSEWOOD BRO....
Dude your shits clean man, and we are rockin the same intake.
Check out my MRT if you get a chance.
BB6->http://cb7tuner.com/vbb/showthread.php?t=200445<Summer Lover
BD6->http://cb7tuner.com/vbb/showthread.php?t=194262<Dailey/Future AutoX
Mazda 6s->http://cb7tuner.com/vbb/showthread.php?t=201313<Wifes
CB7->http://cb7tuner.com/vbb/showthread.php?t=189108<Sold
Originally posted by DjM_coupe View PostLook on your drivers side jamb for yr503m or yr503m-3
Is your thumb getting back to normal? Or will it ever? damn
haha yah im good. i actually already had checked out your MRT i almost got those headlights a while back too.
Teaser pic from bodega bay
i was hoping to get good pics but weather sucked the whole time and i couldnt find a great spot. there was a cool delapitated wooden ship but not enough rooom to frame a good shot.
wanted to take pictures with the new accord
Blurry
i ordered some morimoto mini H1 projectors today though.
pics or final decision on retrofit?
im looking for a DIY for the USDM housing, i know ive looked through one before. looking back at your pictures i think it was your DIY i remember whoever it was used PVC pipe and it looks like thats what you did too. theres this one but pics no work http://www.cb7tuner.com/vbb/showthre...highlight=audiLast edited by Quashish; 08-28-2012, 08:56 PM.
Both.
Ask SPLCB7 about retrofitting H1 minis. He used JDM 1-piecers, but it should be fairly similar. Since the USDM housings have MUCH smaller 9006 bulb sockets, the H1 morimotos will fit MUCH easier than the D2S.
I actually never made a DIY, i just have a few pics of the process i went through. If you have a small diameter hole saw, you might just use that to ensure that the threaded portion of the rear of the projector housing makes it through the rear of the housing. That or use a belt sander and shave off the material you need to get the rear of projector thru it. Then notch it for the locking ring...then all the kit requires you to do is tighten down the locking nuts and BAM, the projectors are mounted. Then put it all together again and wire it up.
This is just a rough idea of what you may need to do. I'd be happy to help you as you go thru it. Like i said before, it's actually quite simple once you get it all in front of you.
Edit: I found the most recent H1 mini retrofit into USDM housings. I hope it helps...http://www.cb7tuner.com/vbb/showthread.php?t=186697Last edited by islandhopper; 08-28-2012, 09:44 PM.
Oh thanks
I've seen like 4 one piece retrofits.
And yah I went with H1 because the guy said less cutting. But I have a dremel and stuff should be here by monday or tuesday.
How long did it take you to do one headlight?
