Oil in spark plug hole
    I was goin to check my plugs and when I pulled the boot to the wire it was drenched in oil, as well as 2 others. One was ok. Can anyone help me with this, thanks
    It's either your upper or lower tube seals that need replacing.
    02 Crv
      So is that my valve cover gasket? How do I check which one it is and what is it called that I'll need to order? Thanks for the reply
        Your upper seals should come with the valve cover gasket set, but the lowers will not an the lowers are underneath the rocker assembly.
        02 Crv
          Ok now what and where is the rocker. Im new to all this, also had hard is it, thanks again
            http://www.youtube.com/watch?v=wYU8q...layer_embedded
            Here ya go, this guy knows his shit, listen to him and follow him to the T!
              Little research goes a long ways, heres a thread that should help you DIY step by step.It's actually quite simple....
              http://cb7tuner.com/vbb/showthread.p...ght=tube+seals
              02 Crv
                Thanks I appreciate it, great info
                  Np
                    You gotta do the valve covet gasket and seals right I had to do mines again after doin it once because they still had oil in them and I took my time on this last time and no oil in the spark plugs it's been like 2 months and still nothing.
                    92 Accord Cb7 ^^
                    My Ride Thread~~Click Below.
                    http://www.cb7tuner.com/vbb/showthread.php?t=176232
                      Thanks for all the replies, but can someone tell me how to distinguish between the upper and lower seals which is bad? How do I check this? Do i have to remove everything and just get to the lower seal to know or is there a way to check whIch is bad before doing that?
                        If your uppers are bad more than likely the bottoms are bad. Because the fact the uppers are old nobody probably bother to replaces the lowers so they have gotten brittle and craked.
                        STANCE|WORKS
                          I did my top ones and it was fine I didn't even touch the bottom ones you gotta do stuff right place the upper tube seals correctly and not squeeze them in there.
                          92 Accord Cb7 ^^
                            The cheap ass felpro kit comes with all of them. Grab that and replace them all. Adjust the valves when your done.
                              its not that hard to do i would also adjust the valves why your in there
