93 Honda Accord with JDM H22A - CEL/SMOG
    Hello fellow CB7Tuners!
    So I'm kinda stuck in a bad spot right now.
    First off, the guys that wired my harness for the JDM H22A swap, back like 8 years ago, somehow hid the diagnostic plug, so I can't find it to check what CEL code I'm getting.
    Basically, I'll drive for about 30 minutes and then the CEL will come on. But when I shut the car off, and then turn it back on, it doesn't come on, unless I drive yet another 30 minutes. What could this be? Gas cap? EGR valve?
    Also, I'm located here in Southern California. Anyone know any smog shops in Los Angeles that don't care about the visual and will pass my H22A? We're planning on selling this car within the next year, once I graduate college, and therefore just need a quick pass.
    Thanks!
    If it matters, I already did a spark plug wire, plug & oil change yesterday night. Car seems to be running great. Bought some Carb cleaner to see if I can clean out the EGR valve of any carbon. What else is recommended to be changed/replaced, to get it to pass smog?
    new $10 purple/yellow tint fog lights
    H22a Sleeper:
    http://www.cb7tuner.com/vbb/showthread.php?t=124470
    Your shooting blind. Find those wires for the ecu. OR find the color wires, look at a diagram and find it on the pins on the ecu.
    And whats failing on smog. I can tell you to do everything in the book, but without you telling us what it is failing then I cannot help you efficiently
    And whats wrong with your car visually? What things are in there that are not supposed to be there?
    Retro!
    Hater
      1 long blink is 10's 1 shot blink is 1 . say ---------- this is 10's (long blink) and this is - is 1's ( short blink) . so ---------- then - this would be a code 12.
      sorry as i am camera shy .
      this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
      Car safety checks
      Fluid Capacities
        Visually it's failing. Basically, its not that something is there that shouldn't be. Because everything is there and looking stock. The only problem is, they say the motor doesn't match the VIN (duh, it's a swap). But they look at it, and say "no I can't smog it", without even trying.
        Thanks, but yeah, I know how to read the codes, just can't find that dang self diagnostic plug.
        H22a Sleeper:
          look for them two wire's . if the engine does not match the vin you will need to take it to the smog ref . they will tell you if it is stolen and help get it registered to that car for 8.25 . if it is stolen then you're looking at jail time .
          Car safety checks
          Fluid Capacities
            So I am to understand that if I buy a used car from anywhere and the state of California determines the engine is from a stolen car then I go to jail even if the car was purchased at a used car dealer.
            http://i220.photobucket.com/albums/d...82408002-1.jpg
              I bought the engine from Hmotors, which many members on here are familiar with, I hope. So I don't think it's stolen. But thanks. I was looking for more on the lines of skipping the smog ref's, and just getting it smogged somewhere. I plan on selling it next year when I graduate college.
              H22a Sleeper:
                CEL Code 17 & 12
                So I found the self diagnostic connector. Had to rip apart the carpet to find it...
                I checked it, it did 1 short then 7 blinks, then 1 short then 2 blinks.
                Came to the conclusion that was 17 & 12.
                17 saw it to be the VSS, that could explain why our speedometer doesn't work..
                12 saw it to be the EGR Lift Valve, we cleaned out our EGR valve, and we put a vacuum hose to the EGR valve, and the diaphragm stayed up, until we released the pressure.
                Could we have a faulty EGR?
                & where is the VSS located? Anyone have a picture of what it looks like?
                We have an automatic transmission.
                Thank you!
                H22a Sleeper:
                  vss
                  vehicle speed sensor
                  look under google images and match it up
                  its on the top of tranny
                    vss
                    Thank you! Found it!
                    Gotta change that tomorrow. Auto parts stores are closed.
                    I guess for the CEL Code 12, EGR Lift Valve, I need to clean out the carbon on the ports/passages.
                    *sigh* more work... Oh well, it'll benefit the car, I guess.
                    H22a Sleeper:
                      can you show us a video of the codes ? because the way you put them don't ad up to me . to get a code 17 it would be one long blink then followed quickly bey 7 short. same thing with code 12 but just two short not seven . way you typed it code 1 , code 7 , code 1 , code 2 .
                      edit: also if you skip the smog ref and smog it illegally that can come back on you . if you sell it like that then thats even more trouble for you . i go to mjc college and have my car smog only cost 8.25 if i don't pass it's free .
                      Car safety checks
                      Fluid Capacities
                        Yeah I decided to just extend my smog, replace to US Emission parts, and get it BAR'd, so that we can sell it later for a lot more, instead of junking it for $200. LOL, if it's possible later, I'd like to get 2G's for it than 200.
                        And sorry if it was confusing, but yes, like how you said it, "one long blink quickly followed by 7 short, one long blink quickly followed by 2 short" So it was Code's 17 and 12.
                        Code 17 is an easy fix. Just need to save money to buy a $150 part...
                        Code 12 it can be easy I guess, but just having trouble finding EGR port plugs, and just constantly looking at videos of how to do it properly.
                        EDITED: http://www.cb7tuner.com/vbb/showthre...+port+cleaning
                        (Guess it's always important to look on forums/threads before posting)
                        H22a Sleeper:
                          j/y in my area has a section that the guys will actually buy a for example
                          1990 Accord with a blown engine or tranny, then pull a good used one from stock, install it and without turning in the title as "junked" will resell it at the used car lot up the street from them
                          i know this because a neighbor of mine did it with his 90 sedan and we passed the used car lot about two weeks later and saw it in the lot
                          j/y paid him $250 for the car, lot had it for $1500
                          same owners of the j/y and lot
                            I believe it, my dad used to have a Pontiac Firebird, there's supposedly a glass that covers the gear shift chain? I forget what exactly, but we junked it for $200, and we passed by a used car dealer across the street from the junk yard, and saw them selling it for $2,000 with new paint..
                            H22a Sleeper:
                              the basic term is "flipping"
                              and on a few tv shows they show it being done
                              one show had the host getting 4 or 5 Pontiac Grand Am's from the late 80's, all the same year body style
                              his guys and him paid a total of $800 for the cars and spent a week swapping stuff between the cars and in the end of the show sold two for a total of $4500 and scrapped what was left of the rest after selling off certain parts to other owners of the same type car.
