Originally posted by bobbycos
View Post
93 Honda Accord with JDM H22A - CEL/SMOG
new $10 purple/yellow tint fog lights
H22a Sleeper:
http://www.cb7tuner.com/vbb/showthread.php?t=124470
Originally posted by JDM_H22_SLEEPER View PostAh yes, that's the term for it.
it depends on the car usually but
Originally posted by bobbycos View PostSo I am to understand that if I buy a used car from anywhere and the state of California determines the engine is from a stolen car then I go to jail even if the car was purchased at a used car dealer.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by Accord problems View Postsorry that did not see you're post . but yes you can be looking at jail time or a really hefty fine . it's called receiving stolen property . California has very strict law's even on our gun's .
H22a Sleeper:
Not to be an ass but visually change the rims throw some racing seats in and it should pass oh and don't forget to lower it. Your inspector that's trying to pass you is probably a JDM enthusiast and will not pass you unless you go all in with your swap j/k.
Just find that plug I'm sure its there its probably tucked away or taped up in there hi or in a corner behind the harness where you can't see it. It should be blue in color.
Originally posted by h22sparkle View PostNot to be an ass but visually change the rims throw some racing seats in and it should pass oh and don't forget to lower it. Your inspector that's trying to pass you is probably a JDM enthusiast and will not pass you unless you go all in with your swap j/k.
Just find that plug I'm sure its there its probably tucked away or taped up in there hi or in a corner behind the harness where you can't see it. It should be blue in color.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
