#41 | |
I'm too lazy to search but if you look for threads started by H23Accord in here you will find the reviews. Maybe I will post them up later. They were good threads. |
#42 |
I got rebound and compression numbers for the Bilstein HD's! Especially make sure to compare those numbers to those of the Koni
STR.t. Notice the Koni is stiffer in the front, but the Bilstein has around 3x the compression in the rear.
There are no black and white suspension answers!!!!!!!!!!! |
#43 |
Keep in mind the Konis are only rebound adjustable. Interesting info for sure though.
#44 |
Right, they're specified in the OP. I also added some info about rebound and compression for those that don't know.
#45 | |
Moderator
When the front is lowered 2.2"-2.25" and the rear is lowered 2", there will be about the same amount of gap between the tire and fender all around. If you lower is 2" all the way around, you'll have more gap in the front than in the rear.
![]() 1999 BMW M3 2001 Honda CR-V SE RT4WD 2005 Chevrolet Tahoe Z71 2015 Suzuki V-Strom 650 |
#46 | |
yea i just ordered mine i cant wait |
#47 |
Moderator
Yes. You'll need shocks that will withstand that drop and spring rate. You'll also need to get an alignment afterward.
#48 |
i'am getting my coil overs put on this week. what kinda bill around about will i have ? what did so me of you guys have , if you paid to have them put on ? thanks guys.
#49 | |
![]() and if your removing your springs then you can rent a coil spring compressor from advance or most parts stores and when you take it back you will get a full refund. ![]() |
#50 |
just a quick question here ... I know its not talked about as often as it should be ... but what about the setups for WAGONS ... because of the extra weight in the back.
What would you guys suggest ?? something for a low stance but not to bouncy... a little bounce would be acceptable. |
#51 | |
#52 |
![]() How can I convert these measurements back from lbs/in to the metric form? I find it (like most other metric measurements) easier to read... ![]() |
#53 | |
Example: 300lbs/in spring / 56 = 5.36 kg/mm
#54 | |
#55 |
Not a problem. Most springs out there are listed in lbs/in while most full coilovers are listed in kg/mm; i find that interesting. I wonder if it has to do with the country of manufacture...............
#56 |
mndude07,
What about these? Not a whole lot of info but still a new brand to add to the list, that someone might have out there: http://www.andysautosport.com/honda/...c00001402.html |
#57 | |
#58 | |
![]() NINJA EDIT: THEY DO GROUP BUYS!!!!!!!!! See Link: http://xyzsuspension.com/contactus.html |
#59 | |
#60 |
I'll be sure and send them an e-mail on Monday to ask about their group buys, and spring rates/damping info for you
Thread Tools | |
