f22b dohc built head
    hello ive just made a pretty big purchase and was wondering if i need to run adjustable cam gears or not..
    crower cams stage 3 na p/n:62483-2
    valve spring, ti retainers, and retainers p/n:84177
    supertech valve , valve gudes , and valve stem seals
    im super excited to have a rough idle
    No marathon gets easier later. ...
    Yes on cam gears. Is this a turbo or n/a build. Eaither way port the head to really get the benafits from those cams.
    my new turbo build
      Many people elect not to use adjustable gears, as they can be a pain to set perfectly. I don’t believe it’s necessary, but it’s true that you’ll be able to pull more from your setup with a good set.
        scored big today
        i think im will get it tuned with the stock cam gear for the time being unless i can find a good set of b series cam gears that someone would trade parts for.. i scored an h22 block with goodies and m2s4 (h23usdm) transmission for 80$ from a facebook group today
        alternator relocation bracket & a cable to hydro conversion
        1320 balance shaft delete with a newish oil pump
        ks tuned manual tensioner (the OG)
        innovation ef trans mount
        a low mile xtd 7 or 8 pound flywheel, 6 pluck clutch, & pressure plate
        h22 has new ring but the kid did not gap the ring and scored the cylinder walls..=( he also said it has king race bearing in it as well
        do you think i could reuse the ring in another block that has low comression if i gap them properly ?
          this is going to be an n/a build for a while I wanna rebuild the lower end for the big boost before I go turbo
            XTD is crap. That exact clutch is what put my cb7 out of commission (ended up being permanent, due to an unrelated incident). At the very least, use an oem throwout bearing. The xtd one will most likely seize on you.
            B series cam gears? Why?
            The H22 has FRM cylinder walls. Very delicate, and difficult if not impossible to repair when damaged. A scored cylinder wall may mean that block is useless without an expensive resleeve. If you’re interested in boost, now is the time to beef up that block for it.
            If you’re building another block, I wouldn’t use parts that have been in a failed build. That used ring had seen the wrong end of a cylinder wall. I doubt it would seal properly.
            Don’t cut corners on things that will be expensive or frustrating to correct if they fail.
              Also, why is this in the appearance section?
                Why are you gathering h22 parts for the f22b head? I’m confused here
                my new turbo build
                  for 80 buck i could not pass it up ill be transfering the manual tensioner and the balance shaft delete the alternator relocation bracket all on the f22 im selling the rest.
                  im going to post this in the rite thread like deev said i accidently posted this in the apperence section
                    I moved it for you.
                      The f22b is Manuel tensioned already
                      my new turbo build
                        i dont think mine is, but ill post pic later to confirm.
                        ill be pulling the motor out today and taking it apart tomorrow
                          F22B should be manual. H22 is auto, unless the previous owner converted it.
                            I actually have a set of Brian crower cams in my turbo coupe. They are the biggest set I could get from them. They are about 7 years old lmao. I don’t have cam gears on mine and I regret not getting them befor the tune. If I were you I would get a very good set. As for your tensioner, all f22a/b motors are Manuel tensioned. Only h22a and f20b came hydrolic.
                            my new turbo build
                              Does Manuel have to do the tensioning? Can’t it be someone else? :-p
