h22a1 no start PLEASE HELP ASAP
    all i can think of is get a test light and a service manual and see where all the place u have power and where u dont
    h22a4+p2u5 trans+8000rpm= 135mph in 4 gear
      Ok
      If you are sure that you have no spark, then the best bet would be the igniter, even though the dizzy is newish. Take the one out of your dizzy and turn the car on, drive it around the block and thank god you belong to this forum.
      201 Whp H22a with bolt ons, see the progress from stock f22a to now HERE
        Wait...
        Did it not work after the guy stole the cd player, or did he just stop driving it after that?
          Since you now mentioned the fact that the CEL is on with code 15
          The issue is either a faulty ignitor.
          12V isn't present at the Black/yellow wire on the 2pin connector at the dizzy.
          Ther is an open in the wire between the ecu and dizzy on the Yellow/green wire.
          Or the ECU is fried.
          My 5.7 LS1 Holden Ute
            what ecu's can i use i have a stock on for a f22a6 would it work
              Any
              Any obd1 ecu will work to test for spark, it won't run well, but if you have spark then you know that is your issue.
              I still recommend putting a known working igniter in and trying that as well.
                thanks i'll try that and let you guys know
