passenger floor wet from ac
    it only happens when the ac is on. if i hit hard turns the water will splash onto the floor. also when i look up under the dash things are all wet.
    Your drain tube from the AC is clogged. Find it, and blow it out with compressed air. Common problem, not the end of the world.
      yeah drain hose clogged up or popped off. later.
      Avoiding dirt at all costs
        The drain tube is under the glove box. There is some ducting under there, and it looks like it go to a point with a tube sticking out of it. That's your drain tube.
          its probably just road dirt on the end of the tube, its under the car, behind the steering rack , random tube, cannot miss it, brign something under to poke into it to clear out the dirt
            Use a metal coat hanger works great to clean it out I did it to mine and never leaked again anf if the plug is missing just use a bolt or screw that fits the hole
            1992 lx sedan-christy-my black beast
