Well guys, my car just started with this problem when driving the car just turns off its quick no sputter or anything just cuts off and it turn on right away. What could be the cause of this it has new plugs cap and rotor. Almost feels like the fuel just cuts off.
Need help car keeps turning off!!!
Take a look at my MRT!! Thanks
http://www.cb7tuner.com/vbb/showthread.php?t=186609Tags: None
No it doesn't do it when I hit bump or anything it's just random. Oh and when I say it turns on right away i have to start it with the key. Ground are good just redid them.Take a look at my MRT!! Thanks
Thanks guys, I'll try the main relay then I was thinking it was that but not sure and re check the grounds too.Take a look at my MRT!! Thanks
I doubt its the main relay as a malfuctioning main relay usually manifests itself by hard starting, predominantly in hot conditions such after having been on a drive (then switching off for refuelling then not restarting) or on a hot weather (not by the engine dying whilst driving).
However your symptoms is similar to a failing ignitor (inside the distributor) module - from my experience .
Get it fixed asap as from my own personal experience it will more than likely compley die sooner (rather than later - within a week for me) where it will no longer start and will leave you stranded.Last edited by JDMDriver; 03-12-2012, 09:15 AM.Rides:
Accord
CR-X
88-JDM-Si- Black
CR-X Del Sol
92-JDM-SiR "Transtop" - Black
Prelude
Well I got it. It was the main relay it was prety bad I should of taken some pics before I fix it. But it's all good now. Never had a failed ignitor but I have had a failed coil but it would studer a little before it would turn off. But thanks guy I got some gd tips.Take a look at my MRT!! Thanks
