How do i get my car into neutral without it running?..
    Cant find the key that goes by the shifter so i can move my car into the garage,any way to get around the lock or to just move the shift linkage by hand?
    Follow me on IG to see my builds/pics
    dmfb919
    Automatic? There should be a release that you can activate with your key. I just had to do that yesterday in my 05.
    If it’s manual, you should be able to move through the gears freely. If you can’t, something is broken.
      Can't you just use another key or something shaped like a key to just depress the park release? I don't think it actually requires the key from the car, just something to press down the mechanism in the shifter assembly.
        Its automatic,it looks and feels like something is broke off in the key hole,i tried the ignition key for about 10mins before i shined a light down the hole. Looks like a broken knife blade lol
        dmfb919
          You might have to take the center console out then to actually gain access to the shifter assembly. I think you can see that area where the shift lock is on, once the console is out. Your other option is to put the key in the on position use the brake and take the car out of park without the car running. You have to leave the key in the ignition until after the car is moved then turn the key off and remove.
            Tried turning the ignition to on and applying brake to shift it,its still locked when i try it. Im gonna tear the console apart when i get to the garage and see if that works..worst case scenario ill just drag it into the garage,i got a 5spd on standby lol
            dmfb919
              Yeah, if that hole is jammed, you’re going to have to do some surgery.
                Yay me lol looks like ill be busy all day tomorrow lol
                dmfb919
                  Figured it out...threw a fresh battery in it to roll the windows down so i could try to steer the car and figured I'd try the console key one more time..it worked lol all it needed was a battery,the broken piece inside doesnt seem to bother it either,so i think I'm in the clear
                  dmfb919
                    Well, yeah. It’s an electrical release.
                      I didnt know that it needed power to release. I feel dumb now lol
                      dmfb919
                        Actually, it doesn't (just verified this on a shifter out of the car). You don't necessarily need a key either, just something long and narrow. After inserting something into the key slot, you do still need to depress the button on the shifter handle to get it out of PARK.
                          The key slot next to the shifter (his is jammed), or the ignition slot?
                          I believe the release via the ignition slot is electrical, no? Or is there some sort of release linkage?
                            I haven't driven my Accord enough to know, but I remember with a lot of GM vehicles once the car was parked and turned off, if you cranked on the wheel a bit you coud lock the column in place real tight, and unless you exerted some pressure on it while trying to turn the key, the ignition wouldn't unlock it (automatics only obviously).
                            Maybe something like this was going on?
                              Sorry for the confusion. Yes, when using the key in the ignition, the release is electrical. When using a key (or any other long enough narrow object) in the slot in the shifter, it is mechanical.
                              It didn't physically lock it; if you crank the wheel over before shutting off, the force trying to return the wheel position gets reacted against the locking pin making it very difficult to turn the key (I suppose even to the point of breaking something - effectively locking it) to retract the pin from the locking slot. This happens occasionally in my Accords for the same reason. As you stated, you have to "unload" the steering wheel to allow the locking pin to slide. This should have no effect on being able to release the shifter mechanically via the key slot in the shifter.
