how often do you have to change the fuel filter?...i have a 92 accord with about 95000 miles on it...am i way past due for a filter change?
fuel filter
depends, usually the interval is 30k. i didnt change mine till 150k...didnt notice too much of a difference, but in cold weather and bad gas u need it to change it more. the part is 23 dollars at the dealer.
imma change mine every 50What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by HondaFan81
Fuel filter changes depend on the quality of the filter you buy. Honda filters are supposed to last like 30,000.
I know some cheap ones last only like 10-15,000Visit us at http://www.valleyspecialists.com for all of your Honda and Acura service needs!
SHo Nuff- Your not trying hard enough!
Yes, they are a biotch to remove!
It MUST be done though!
Try putting a wrench on BOTH of the bolts on the fuel filter. When you turn one, the other wrench will stabilize the entire assembly and prevent damage.
Also try to SOAK the bolts in wd-40 or a better "freeing" lube.Noobie my ASS.
yeah, its a bitch to remove...took me a long time just to remove the first bolt and the third...the second one wasnt too long its hard, but keep working at it and it'll come loose eventually...btw, i did mine last week
Originally posted by fizzbob7first off, don't be a sissy bitch.....that's what you're beingOriginally posted by ACC0RD22no need to get sand in your vagina over this guys.
I bought a purolater fuel filter a while back but I haven't installed it yet. Should I get rid of it in favor of a honda OE part or does it make much of a difference? Just curious.FSAE(F Series Accord Enthusiasts) "A dying breed..." #15
Need parts? Check out my 1990 EX part out!
http://www.cb7tuner.com/vbb/showthread.php?t=60011
www.clemsonscc.com
