tire size?
    tire size?
    will P235/60R14 tires fit on my accord? or will they be too big to turn and what not??
    Check out my MRT: http://www.cb7tuner.com/vbb/showthread.php?t=189190
    That tire is too wide. I'm not sure about turning issues but you'll have issues with going over bumps because of the tires hitting the inner fenders.
      They should fit but it'll be really tight.
        Are you on stock suspension?
          Yes, everything is stock
            Do you have a wagon?
            If so, no, a 14" wheel won't fit regardless of tire size. Wagon brakes are larger and require at least a 15" wheel.
              Did LX wagons come with 15" steelies?
              He has an LX sedan, so it doesn't matter anyway.
              A tire that wide would be bulging over the side of a stock rim (or even a commonly sized aftermarket rim), causing handling to be extremely "squishy"... that much may even roll enough to unseat the tire and cause you to lose control.
              Stock tire size is 185/70/14. To put it in simple terms, that's "width/height/diameter"
                Yes.
                  That's kinda cool. I didn't know that... or I forgot it. Either way, it was not found in my brain!
                    I never knew that myself. So the LX wagon wheel covers are just 1-inch larger versions of the same style wheel covers that the LX sedan and coupe had?
                      they're a bit different:
                      they still used "hub caps".
                      sorry for the
                        No i have the rims too! i was going to save money and take the ones from my dads 280zx since he does not drive it and it has the same lug patture! so if i had the right size rim too, this tire would fit?
