Relay problem?
    look in the faq and look under the main relay. You will be able to listen.
    If you turn the key on and watch the check engine light, you should hear a click when it turns off, it SHOULD START. If you did hear a click and it didnt start then its something else.
    If you turn the key on and watch the check engine light, You DONT hear a click, I guarantee it wont start.
    The click is the main relay clicking.
    Retro!
    Hater
      Hmmm thats weird, when i turn the key i get no check engine light but i hear a click and it starts.
        Someone may have pulled the bulb
          does it ever NOT start and you hear a click? Or NOT start and hear no click, try it a bunch of times.
          The click is heard in the dash just incase you were wondering.
          Retro!
          Hater
