sway bar endlinks...???
    i have just purchased a pair of trw sway bar endlink kits and i need to put them on...can i just put my car on jack stands and put them on or do i need to get them done by a pro it doesnt seem like that hard a job when i look at them but they need to be changed asap cause the rubber grometts are gone and i dont wanna lose my axles cause of this!!! please help
    GOT SOMETHING SPECIAL FOR YALL .....STAY TUNED
    if you know how to jack the car up, and remove the wheels, you can install these yourself. you probably have the tools already... ratchet,
    socket(s), wrenches. no need to pay someone to get this done. good luck.
    5.6L V8 32V DOHC
    JDM HERITAGE - US BUILT
      yeah I did mine it took me like 2 hours from start to finish but teh actual work was a peice of cake, just unscrew the old ones and put the new ones in
      My Members Ride Page
        I Have seen people drive without sway bar links for years and never loose axle the only thing they do is keep the car from swaying its more for better conering some vehicals don't even come with sway bars at all, the only way it would take out your axle is if they feel off and rubbed your axle boot or something even then u would see the grease or hear it rubbing. there not hard to change at all thought worst ive seen is u need to torch them off if there rusted on bad or at least a impact "air" gun! just to knock them loose. lol depends were u live. I live in northern ontario canada so things rust up preaty good here on most vehical's
        Torch_ind
          thanks for the help guys its done and it corners a hell of alot better
