So I've been told that in hondas like my cb7, the idle speed is controlled by coolant flow. When I bought my CB7 in november, The idle would surge up and down whenever it was in park or neutral, and most of the time when it wasnt surging it would be idling around 1100-1200 rpm. It also had a thermostat which was stuck open, I changed that and decided to flush the coolant while im at it. I put in coolant and bled the system of air and it was fine ever since, idle went down to 850 rpm when warm, no more surging. Recently I found a pretty big hole in the expansion overflow hose right where it connects to the radiator neck, it was leaking coolant (engine was hot when I discovered this) I'm not sure how much leaked out, wasnt very obvious. I just snipped off the damaged section of the hose and reconnected it, no big deal. Today I noticed that when I start it up from a cold start the rpm shoots up to like 2500 and doesnt go down until the engine is starting to warm up, once warm, the idle is at 850 like normal. I haven't gotten a chance to check the coolant level because my dad drives my cb7 all the time because he likes it more than his own car -_-
But could low coolant be causing the high idle?
