Go Back   CB7Tuner Forums > Member Shops > Member Shops > Explicit Speed Performance Shop
Closed Thread
Old 04-10-2008, 04:03 PM   #1
ESP-net
CB7tuner.com approved seller
ESP-net is cool... so far.
Send a message via AIM to ESP-net
ESP CB/CD 90-93/94-97 Accord Traction Bar Systems With or Without Front Torque Mount
www.ExplicitSpeedPerformance.net
Email: ExplicitSpeed360@aol.com
AIM: ExplicitSpeed360
Phone: 1-360-866-8530 Monday-Saturday 10am-5pm
Ask for John
CB/CD Accord Traction Bar System With or Without Front Torque Mount Kit H and F series Motors
It is a direct bolt-on with the use of the stock factory bolt holes and radiator. It is built strong and built to last! It's made of 1 1/2" x .170" square tubing and 1/4" thick plate. Everything is mild steel. It comes complete with swaged polished aluminum radius/tie rods and chrome-moly heim joints. Also comes powdercoated semi gloss black. Our radius/tie rods are mounted to the LCA with our double shear brackets which are pictured below. The double shear brackets spread the load over 2 points instead of one creating a stronger attatchment.
Over 150 powder coat colors to choose from, will cost additional other then our standard semi gloss black. Comes with Red Decal but other colors available.
Benefits:
You will notice wheel hop on the Accord your nose will raise up and tires will loose traction. Our Traction Bar System will keep you nose down and keep the power where it needs to be the ground. If you have non LSD transmission you will notice torque steer. Your car will go to one side under launching. Our Traction Bar System will keep your car straighter under the torque steer.
- Help prevents wheel hop
- Help prevents torque steer
- Strengthens the front end
- Provides better handeling and cornering in bad and good weather conditions
- All cars should have one even daily drivers, I run one in all of my cars.
- This same design has been tested and abused on a 700 whp CD Accord and the Worlds Fastest BB Prelude
- Built Strong, Built to last!
Our Traction Bar System is not just for drag racing. The stock front cross member is thin and weak compared to our Traction Bar System and will make a noticable difference in your all around driving experience. Toss your old thin weak cross member for our unit. Our Traction Bar Systems are also used on Circle Track/ Road Race cars. They swear coming out of corners the car is quicker and for Turbo Road Race cars they are able to run more boost because they are achieving more traction out of the corners.
Without Front Torque Mount Kit but with prevision for later upgrade:
$350 shipped US
Front Torque Mount upgrade Kit:
$100
With Front Torque Mount Kit:
$450 shipped US
Double Shear Brackets
Front Torque/Mount kit with use of F and H series motors
Uses polyurethane bushings on each side to soften the mount as well as being adjustable to adjust how much tension you want on the front mount. Replaces stock front mount. It will clear the stock radiator and fan.
Benefits:
- It will eliminate unwated engine movement forcing the power to the ground.
- The Front Torque Mount Kit is adjustable so you can adjust how much tension you want on it. Really neat.
- Smaller in size then the factory bulky front mount and bracket. Clearance is an issue for Turbo applications and our Front Torque Mount Kit gives a lot more room
Is a must
Bright Red
Neon Pink (Very Bright
Candy Blue Metallic (Shiney Si Blue)
Takatta Green (Shiney Candy Green)
CB/CD Marron OEM Color (Shiney Candy)
Mounted to a GT40 700 whp Top Mount Accord with 3" downpipe
__________________
Custom Engineering and Fabrication
Motor Mount Kits, Traction Bar Systems, Solid 2/3/4 Pt Strut Bars, F22/H22/H23 Alternator/Tensioner Kits and much more...
ESP-net is offline
Old 04-10-2008, 10:31 PM   #2
F20A CB7
Contributing Member
F20A CB7 seems to have made some friends! F20A CB7 seems to have made some friends!
Nice, great job on mixin up the colors.
__________________
F20A CB7 is offline
Old 09-29-2008, 03:08 AM   #3
slammed4thgen
The Jerk
slammed4thgen seems to have made some friends!
Send a message via AIM to slammed4thgen Send a message via MSN to slammed4thgen
yet again, esp.net delivered.
high quality goods for a nice price!
didnt see any difference in 60 ft but there was no traction to be had by anyone, track conditions were awful so time will tell.
HOWEVER! this improves handling like crazy! the front end feels so much better going in and coming out of turns. absolutely worth the money just for that in my book!
dont hesitate, if you are eyeing this get it
thanks again john and ill be in contact
__________________
smoke tires, not drugs.
slammed4thgen is offline
Old 11-25-2008, 03:01 PM   #4
ESP-net
__________________
ESP-net is offline
Old 12-18-2008, 06:33 PM   #5
ESP-net
__________________
ESP-net is offline
Old 03-20-2009, 04:49 PM   #6
ESP-net
Here is a picture to showcase the bronze pearlescent comes out like a gunmetal/bronze color
__________________
ESP-net is offline
Old 03-20-2009, 04:54 PM   #7
RICHIE*GT35R
SouthEastern Regional Moderator
RICHIE*GT35R seems to have made some friends!
Send a message via MSN to RICHIE*GT35R
Quote:
This one is mine!!!! Can't wait to get it.... Thanks
RICHIE*GT35R is offline
Old 05-18-2009, 03:01 PM   #8
samrjr0044
Contributing Member
samrjr0044 is cool... so far.
Definately thinking about ordering one of these.
samrjr0044 is offline
Old 09-01-2009, 08:25 PM   #9
ESP-net
From Now Sept. 1st to Sept 15th I will honor the above deal !!!
Make sure to mention the Sept. Discount !!!
__________________
ESP-net is offline
Old 10-27-2009, 03:39 AM   #10
nostringz
CB7tuner Member
nostringz is cool... so far.
wow must buy, but i still need a rear sway
__________________
Be Clean
nostringz is offline
Old 03-18-2013, 05:50 PM   #11
ESP-net
1st Page Pictures Back Up!!! Still Going Strong!!! Check out our Spring Sale!!!
__________________
ESP-net is offline
Old 04-03-2013, 03:14 PM   #12
ESP-net
!!!!!!!!!!!!!!!! GUYS WE ARE HAVING SUPPPPPER DEALS THIS WEEK DISCOUNT ON TOP OF DISCOUNT !!!!!!!!!! Just give us a Call or Email and ask about our Discount!
__________________
ESP-net is offline
Closed Thread
