Go Back   CB7Tuner Forums > Member Shops > Member Shops > Explicit Speed Performance Shop
Old 08-23-2016, 03:20 PM   #1
ESP-net
CB7tuner.com approved seller
ESP-net is cool... so far.
Send a message via AIM to ESP-net
ESP CB 90-93 & 94-97 Accord Traction Bar System w FTMK F/H ONLY Thread
www.ExplicitSpeedPerformance.net
Email: ExplicitSpeed360@aol.com or ExplicitSpeedP@aol.com
AIM: ExplicitSpeed360
Monday-Saturday 10am-5pm
CB/CD Accord Traction Bar System With or Without Front Torque Mount Kit H and F series Motors
It is a direct bolt-on with the use of the stock factory bolt holes and radiator. It is built strong and built to last! It's made of 1 1/2" x .170" square tubing and 1/4" thick plate. Everything is mild steel. It comes complete with swaged polished aluminum radius/tie rods and chrome-moly heim joints. Also comes powdercoated semi gloss black. Our radius/tie rods are mounted to the LCA with our double shear brackets which are pictured below. The double shear brackets spread the load over 2 points instead of one creating a stronger attatchment.
Over 150 powder coat colors to choose from, will cost additional other then our standard semi gloss black. Comes with Red Decal but other colors available.
Benefits:
You will notice wheel hop on the Accord your nose will raise up and tires will loose traction. Our Traction Bar System will keep you nose down and keep the power where it needs to be the ground. If you have non LSD transmission you will notice torque steer. Your car will go to one side under launching. Our Traction Bar System will keep your car straighter under the torque steer.
- Help prevents wheel hop
- Help prevents torque steer
- Strengthens the front end
- Provides better handeling and cornering in bad and good weather conditions
- All cars should have one even daily drivers, I run one in all of my cars.
- This same design has been tested and abused on a 700 whp CD Accord and the Worlds Fastest BB Prelude
- Built Strong, Built to last!
Our Traction Bar System is not just for drag racing. The stock front cross member is thin and weak compared to our Traction Bar System and will make a noticable difference in your all around driving experience. Toss your old thin weak cross member for our unit. Our Traction Bar Systems are also used on Circle Track/ Road Race cars. They swear coming out of corners the car is quicker and for Turbo Road Race cars they are able to run more boost because they are achieving more traction out of the corners.
Without Front Torque Mount Kit but with prevision for later upgrade:
$415 shipped US
Front Torque Mount upgrade Kit:
$115
With Front Torque Mount Kit:
$475 shipped US
Double Shear Brackets
Front Torque/Mount kit with use of F and H series motors
Uses polyurethane bushings on each side to soften the mount as well as being adjustable to adjust how much tension you want on the front mount. Replaces stock front mount. It will clear the stock radiator and fan.
Benefits:
- It will eliminate unwated engine movement forcing the power to the ground.
- The Front Torque Mount Kit is adjustable so you can adjust how much tension you want on it. Really neat.
- Smaller in size then the factory bulky front mount and bracket. Clearance is an issue for Turbo applications and our Front Torque Mount Kit gives a lot more room
Is a must
Bright Red
Neon Pink (Very Bright
Candy Blue Metallic (Shiney Si Blue)
Takatta Green (Shiney Candy Green)
CB/CD Marron OEM Color (Shiney Candy)
Mounted to a GT40 700 whp Top Mount Accord with 3" downpipe
ROSKO's Prelude
Roger's Prelude Worlds Fastest BB FWD Turbo
First come, first serve. PM or Post with questions.
Q: What is a Traction Bar System and what will it do?
A: It will gain Traction and Help Eliminate Torque Steer. It will force more power to the ground and keep the nose of the car down. It will keep the LCA's stationary. Which means will gain Traction. You will notice Traction will grab instantly and go straight rather then off to one side and nose of your car will remain down instead of going up and losing Traction.
It is a guarantee and only way to fly to get your best 60' and 1/4 mile ETs. It is only way to fly trying to go from point A to B the quickest.
Our units are the Strongest on the Market. You can jack on them without every worrying about bending the bar unlike some other units. If the bar bends imagine how stable it is when load is on it...it will give and LCA's will move and loss of Traction.
Q: Front Torque Mount Kit a must?
A: I have personally taken the Front Torque Mount Kit off my car and notice a big difference. Helps out a lot in forcing more power to the ground with eliminating th engines movement.
Q: Is there a weight savings with your ESP units?
A: Yes our ESP units are roughly half of the weight of the OEM pieces. As well as our units much stronger then the OEM unit. On average stock pieces will add up to 45 lbs and ours is roughly 22 lbs.
Q: Are they only for Drag Racing?
A: No that is the old myth. Overall you will notice a night and day difference in overall road response and steering in good and bad weather conditions. Turning will also feel much more accurate. Road Race guys have been running our units for years. They swear they have much more Traction and are able to come into and out of the corners much harder and able to run more boost in turbo applications because of the added Traction.
They are a Win Win!!!
Custom Engineering and Fabrication
Motor Mount Kits, Traction Bar Systems, Solid 2/3/4 Pt Strut Bars, F22/H22/H23 Alternator/Tensioner Kits and much more...
ESP-net is offline   Reply With Quote
Old 10-09-2016, 06:28 PM   #2
ESP-net
ESP Accord Traction Bar System with Front Torque Mount Kit F/H 10.94@137
