Go Back   CB7Tuner Forums > Member Shops > Member Shops > Explicit Speed Performance Shop
Old 02-28-2017, 01:09 PM   #1
ESP-net
CB7tuner.com approved seller
ESP-net is cool... so far.
Send a message via AIM to ESP-net
ESP Catch Can & Coolant Can Combo New Product!!! K&N/Vibrant ESP/850Fab
ESP/850 Fab "The Jewelry Box" Catch Can and Coolant Can Combo
"Small and Compact but big enough for the Big Boys"
Features:
- Larger than Normal K&N Filter and Filter Exit on Can
- Internally Baffled
- Drain back option to motor/oil pan
- Sight for Coolant Level
- Vibrant Coolant Cap
- Coolant 1/4" hose barb fitting
- If do not want Drain Back option will come with Black Cap on fitting
- Front and Rear Mounting Tabs for easy install
Can ONLY with Filter and Sight
$575 Shipped US
Can with 10AN Complete Install Kit to Valve Cover/Motor, Black Fittings, 16 ft Black Hose
$695 Shipped US
This is for a Small Group Buy. I am ONLY doing these 2 at a time. All Handmade and made upon purchase. Wait time is about 3 weeks upon purchase. May be a little sooner. This Catch Can is more than applicable for the Big Hp Guys. No need to run 2 small filters when 1 Big one will do the job. High Quality K&N Filter is used. It is internally baffled which most Catch Cans are not to ensure nothing getting drain back to motor that you do not want. The Coolant Can uses a Custom 1/4" NPT Aluminum Pipe. Dimensions 5" tall, 6"long, 5" wide. We can also adjust the Drain Back to side or on Front like pictured and Left or Right corner. Will come as pictured if not mentioned on Right Side.
This piece is so nice wasn't sure to install it or put it on the dinning room table as a center piece
Built by 850 Fab. Designed by ESP/850 Fab
Paypal Payment
PM or Email with any questions or wanting to purchase
ExplicitSpeed360@aol.com
www.ExplicitSpeedPerformance.net
Custom Engineering and Fabrication
Motor Mount Kits, Traction Bar Systems, Solid 2/3/4 Pt Strut Bars, F22/H22/H23 Alternator/Tensioner Kits and much more...
ESP-net is offline   Reply With Quote
Old 03-01-2017, 07:27 PM   #2
Granite CB7
Granite CB7 is very helpful Granite CB7 is very helpful
Making it into the big leagues working with Blake Barr now Looks amazing!
Granite CB7 is offline   Reply With Quote
