Old 04-01-2019, 02:03 AM   #201
aventari
CB7tuner Member
aventari is cool... so far.
Did you get the RPM window switch I sent? It should've shown up by now!
As for your idle, did you set your TPS voltage with the new throttle body?
aventari is offline   Reply With Quote
Old 04-02-2019, 07:33 PM   #202
ukemike
CB7tuner Member
ukemike is cool... so far.
I did get the device. I installed and and failed to get it working. I got a call back from the company tech support this morning and now I know what I did wrong. Should be working on Saturday. I have not reset the TPS voltage. But I did just search this site and look in my factory manual for a procedure. Didn't find one there but I found some videos on youtube.
__________________
1991 Accord Lemons Race Car, "The Minnow" RIP
1993 Accord Lemons Race Car, "Notorious RBG"
Neuspeed Race Springs, Koni Sports, Acura CL Rear Sway Bar,
Adj Upper Control Arms -3.0deg front, -2.0 deg rear
M2A4 Trans, Cusco 1-way Limited Slip Differential, Stage 2 Clutch and 11lb flywheel.
A4 Header, 2" exhaust all the way back, catalyst delete, glasspack muffler, PT12 ECU.
Acura CL3.0 Brakes Front and Rear, Raybestos St43 Pads, Redline 600 Brake Fluid
ukemike is offline   Reply With Quote
Old 04-02-2019, 08:47 PM   #203
Grumpys93
Contributing Member
Is this what you are looking for?
http://www.cb7tuner.com/vbb/showthread.php?t=159376
__________________
~Nick~
Old 04-02-2019, 09:35 PM   #204
ukemike
CB7tuner Member
Aaaahhh. That's good. Thanks.
__________________
Old 04-28-2019, 12:31 PM   #205
ukemike
CB7tuner Member
The rpn actuator doohicky worked once I figured it out. Actually the folks that made it, Intellitronix, had great tech support. I was having some trouble, I left them a vm on a sunday got a call on monday and they set me straight. The dip switches were a little off on the rpm settings too. But a little testing and adjusting sorted that out.
We aren't going to have time for the cam before this race. So I just have to get the tires and finish a few misc items before May 25. That's good because this is going to be a busy month anyway.
__________________
Old 06-22-2019, 04:01 PM   #206
Bailey_CatDaddy
Newcomer
Bailey_CatDaddy is cool... so far.
What happened to this??
Bailey_CatDaddy is offline   Reply With Quote
Old 07-09-2019, 10:34 PM   #207
ukemike
CB7tuner Member
I forgot to post about our race results. We went to Thunderhill and raced on the full 5 mile track. We were in the top 40 for most of the race. We were actually in the top 30 until our first driver change. But on sunday afternoon the clutch went out on us and we threw in the towel and got out of there early. By the end of the race we were in about 73rd. It was epic and fun. We did have more power for sure. Since then, nothing. We towed it back. We need to swap the clutch but have not done a thing.
Thoughts on what clutch to get?
__________________
Old 07-11-2019, 04:52 PM   #208
Bailey_CatDaddy
Newcomer
Super cool! Glad it was fun.
Iíve had really good luck with the XTD stage 3 and 4 clutches on Nissan RB engines and KA24ís, so I am personally going to get a stage 5 xxtreme XTD clutch (sprung) in a few months when I swap my transmission for an h22 trans.
I recommend the XTD clutches a lot and havenít seen any bad results except where someone didnít adjust their clutch pedal freeplay once and was preloading the pressure plate. Any clutch will be ruined by that, though.
Old 07-13-2019, 09:49 PM   #209
ukemike
CB7tuner Member
Here is how our clutch died, probably from shifting to fast and hard
In the second photo see how the tabs that connect the friction disk have broken. I believe it failed first here, then the friction material must have delaminated
__________________
Old 07-14-2019, 09:09 PM   #210
Bailey_CatDaddy
Newcomer
Wow, thatís actually pretty cool.
Iím sure extra heat, aggression and more heat would fatigue those thin pieces!
Old 07-14-2019, 10:47 PM   #211
Grumpys93
Contributing Member
I do enjoy my stage 4 clutch master 6 puck sprung with the upgraded pressure plate.
__________________
~Nick~
Old 07-15-2019, 10:42 PM   #212
ukemike
CB7tuner Member
My team mate who bought it couldn't recall what brand it was, he just remembered that it was "stage 1". I found a part number on it and googled it. It was FX brand which was also called F1. It's basically a chinese ebay clutch. No wonder.
__________________
Old 07-16-2019, 01:43 AM   #213
Bailey_CatDaddy
Newcomer
The copies of the copies. XTR, FX, F1... there are more, for sure! They usually donít post up clamping forces or torque ratings. Just ďstagesĒ. Which makes you wonder whatís in the box! Ha ha
Old 07-20-2019, 02:42 PM   #214
ukemike
CB7tuner Member
Just ordered one of these
https://www.advancedclutch.com/produ...=p2446-c269538
__________________
