I have had this problem for a long time and just got around to wanting to fix it cause i now have key-less entry and it is annoying to have to push button multiple times to open or lock.
Here are the symptoms.
1.The drivers door lever takes 3 or more times for it to lock.
2. The auto lock is very touchy like barely forward a bit and it tries to lock with engine off. This goes for unlock also.
3. It takes multiple pushes of the button from either passengers or drivers side before it opens or locks with engine off.
4. With engine running it all acts fine.
5.My headlights, stereo and everything else seems to operate fine even with ignition off or on. So am not thinking it is my voltage regulator or battery.
I am thinking it is my door lock control box behind door. Is there some sort of status change in control box when car is started?
