when a strut says it gives u a 1.5" drop, the car is going to drop 1.5" with stock springs. is this correct? if a spring says it gives u a 2" drop, the car is going to drop 2" with stock struts. is this correct? so if i pair these struts with these springs, its going to give me a 3.5" drop. is this correct? sorry but im a noob to suspension. i want a drop but not something more than 2". just want to make sure before i buy anything
strut and spring drop
Members' Ride Thread :http://www.cb7tuner.com/vbb/showthre...82#post2939682
My CB7 Tribute Vid..https://www.youtube.com/watch?v=XqWFstSzLH8
Track ready EK..https://www.youtube.com/watch?v=IoYKsoL0i7MTags: None
No way. Only strut that can give you lowering benefits is the Koni Yellow , and it gives you a drop of 0.25 maximum.
Lowering springs and coil-over sleeves (drop spec varies) , will give you lowering benefits.
1996 Honda Civic LX 2009-2012
2012 Kia Optima LX 2012-2013
The strut will never change the ride height, unless the spring perch is lower (such as on the Koni Yellow, with the adjustable perch)
When a strut says 1.5", that means it shouldn't be used with springs that go any lower than that. The KYB AGX, for example... the warranty is void if you lower your car more than 1.5". They also will not respond very well, and may blow if you go lower.
Lowering springs should NEVER be used with stock shocks, PERIOD. Don't even consider that an option. The spring manufacturers sure don't.
Originally posted by ShayneRizzle View PostYes what you said is exactly correct.
There are a few struts out there that are shorter then stock such as skunk2s and there are even some that lift the car a little like the kyb "drop killers" lol
buzz11: springs are the components that will offer the ride height change. the only exception for the struts are the koni yellows. you also have the choice of coilover sleeves (e.g. ground-control) that offer a range of height variation. if you've got the money, pair those up (yellows and ground-controls) and you'll have all the lowering you want plus reliability if taken care of!
