Rims off an 87 Cressida wont fit?
    Ok so i bought my Accord 5 months ago and i had bought these rims off craigslist for like $50 they have great tires and everything. But i went to put on the rears and the studs werent long enough so i got extended studs. I have the rears in and they still wouldnt fit i found out the hub on the Cressida tires was too small by just a little so yesterday i took my grinder to it and ground them down til they fit and the rears fit beautifully. Now i went to put on the fronts and the caliper has this handle looking thing and it wont let me get the rim all the way on so i was wondering if there are any aftermarket or stock calipers from another model would help me fit these rims
    Spacers will fix your issues
    Bought from:AbsurdNY,92smokeaccord,cb7inct,nevi325,xkjnboix,cb 7resurrector,JoshM
    MRT: http://www.cb7tuner.com/vbb/showthread.php?t=203451
      How big should they be? And how much will they cost?
        Well first you need to find the wheels specs, size and offset. Then go from there. I haven't even heard of someone using them on a cb so not to sure on how many mm spacers you need.
          You can shave some of the caliper to fit the wheels also..
            See i saw that it has like this handle sorta and i wasnt too sure if that was even needed but if i do shave the calier what would i use ?
              The hub bore is 4mm too small, and the offset is about 20-25mm too low. Use wheels that are made to fit your car.
                I have no idea what the does nor mean lol but i put the rears on after a little massaging from my grinder and they fit and they tuck perfectly wish i knew how to post pics it would make this much more easier
                  what he means is
                  you had to make modifications to the rim and your car to make the rears fit
                  and now you will be making modifications to your brakes (a safety system) to get the fronts fit
                  http://i220.photobucket.com/albums/d...82408002-1.jpg
                    Ok i see what you guys are saying its really not worth it to change everything just for these rims. But that leads me to another question are there brake calipers out there that will be stronger and slimmer than the stock ones i have that i could maybe pull off another honda?
                      use the search function and look for threads about calipers
                      see if you can resell the rims
