Logic Motorsports Tri-Y Header
    i just watched a video where three headers were compared, the Logic tri-y, a Bisi, and a RMF. the Logic had a stronger mid, and a higher peak number.
    anyone running these headers on a CB7 w/H22a? if so, what kind of numbers where you getting?
    also, how was the fitment? any crossmember notching or anything? at 399 it was by far the most cost effective choice.
    input?
    really? i assumed a ton of us would be running that header, its only 399 shipped, and it makes more power than a few products priced much higher.
    i want to try it, im just wondering how it would fit in the CB7... will i have to notch the crossmember? who knows.
    i just want a header that makes USABLE power, looks nice, good quality, and value. ive had DC headers and and megan headers, even a bootleg TODA. id like to try an aggressive N/A header, but i cant spend 8 hundo-1k on one. Hopefully someone chimes in, someone on this board has to be running this.
      I've seen that header for sale, and I believe that it's all one piece if I'm not mistaken. To get that header in may be troublesome as I'm sure the radiator and dog bone will probably have to be removed.
      The Lord watches over me!
      - D. Chappelle
        I remember reading some where that the cross member had to be cut a bit.
          yeah i just heard back from the guy at logic, he said you do have to notch the crossmember, and as far as installation, the whole engine will be out already.
            This is true. I saw it on another forum earlier, and the guy had it neatly cut then covered with a welded piece of metal. This was done on a Prelude.
            - D. Chappelle
              you just have to remove the lower cross member and you can fit the header up there fine. its only 4 bolts to remove it so its not too hard. and the notch can be done easily as well, i dont think id have to do it for mine because my hytech replica header has already decided to make its own on lol.
                yeah i dont think its much, not enough to mess with structural integrity anyways.
                  I got one, it's a piece of crap.. Doesn't even assemble correctly. Sooo...
                  Beware of this header
                    what part of it didnt assemble correctly? Its one piece
                    Ive heard its a PITA to get a hold of one of these things. They are always on backorder and the customer service at logic blows.
                    We bought one on ebay for my buddies H2B hatch and its awesome. But that didnt come from direct from Logic.
                      i myself want a tri y with a h23 sc sports flange on it.
                        really? what was crappy? it looks to be a one piece design... what was there to assemble? did the flange fitment suck or something?
                          did it make good power? i just dont see what assembly issues that one guy had with what appears to be a one piece header....
                          i had my heart set on this header, its affordable and i got a line on one as soon as i make my decision.
                            You can't expect many headers to be a direct fit due to all the different chassis engines can be put in. It's simple if the collector is to short or long spend $30-50 on having a exhaust shop weld it up correctly. If you're having clearance issues they're ways around that aswell, but like i said don't expect a direct fit on any aftermarket header unless it is specifically for your chassis and engine combo then and only then should you complain.
                            02 Crv
                              https://www.privatelabelmfg.com/prod...h2b-header.htm
                              This is the header I have, I don't know which header the OP, or whoever in this thread is talking about but.... This header is trash IMO
                              Edit: I see you are talking about a different header, sorry, but do not get this header^^^
