Rear wheel speed sensors seem to be expensive even for aftermarket as oem is discontinued. Can these be cleaned or fixed. I got code 48 for rear left speed sensor and am wondering what is the common problem with those and can it be repaired and reinstalled?
Can abs wheel sensors be cleaned or fixed and reinstalled
Originally posted by zedjr10 View PostRear wheel speed sensors seem to be expensive even for aftermarket as oem is discontinued. Can these be cleaned or fixed. I got code 48 for rear left speed sensor and am wondering what is the common problem with those and can it be repaired and reinstalled?
Originally posted by zedjr10 View PostI reset me computer and i get code immediately after starting car. So my thought is that the link is broken somehow. Wouldn't broken teeth on it show up only when car moves?
Ive got a complete 93 SE rear end sitting next to me in the basement. the car itll go into doesnt have ABS. youve got over 30 posts hit me up if you need to.Last edited by illinois_erik; 12-19-2018, 08:55 PM.
Originally posted by illinois_erik View Postyes, they get loaded up with brake dust and rotor particles, youll see the schmoo move, give them a blast of cleaner wipe em down. scuff off any surface rust on the probe tip. thats about all you can do to them. sometimes an accumulation of ferric dust on it will mess up t he reading of the tone ring..sometimes. you can clean that too. if the grooves are full of shit the computer wont get a nice segmented signal from it.
The first step i should do am sort of guessing is unplug it and test for resistance. IS that correct?
Originally posted by zedjr10 View PostDo i have to take it out and then apart to clean it?
Yes, just unplug it to check resistance.
I have the same code, but it doesn't come on until I start driving. I thought I cleaned it when I changed the rear caliper.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
