Questions about a auto to manual swap
    Do I have to switch out the ecu when doing a auto to manual swap
    Yes, you do
      You can run the auto ecu, but you'll have some idle issues. I believe it also causes some minor weird things to occur around the points where the auto would normally shift.
      It can be done, but you'll want a proper manual ecu asap.
        yes offcourse you have work with the ecu
