Thread Tools Rating: Thread Rating: 7 votes, 4.71 average. Display Modes
Old 08-08-2018, 03:03 PM   #141
Jarrett
Contributing Member
Yeah, I'm pretty excited to be getting so close to having the car back! Though it did pain me a bit to take my brand new, shiny suspension bits up there to put on the car to get it rolling. Of course it's eventually going to get dirty and gross from road use, but I was hoping for some pretty pictures before that happened.
The plan is to get the car back here to Houston not this weekend, but the coming one. Once it's here, I'll lift it up and pull all four wheels back off and remove all the suspension from it. There are still things I need to powder coat like the rear trailing arms, rear crossmember, shock forks and front upper control arms, and I'd prefer not to buy them again. So I'll just wait until the car is here and immobilize it for a while. It's used to a life on jack stands at this point.
__________________
Old 10-01-2018, 09:17 PM   #142
Jarrett
Contributing Member
I hit a pretty decent-sized snag in getting the car down here with me in Houston when I had planned. Nothing is wrong with the Accord, but I had other car problems that took up both my time and the garage space. Story time, in case anyone cares to know.
One of my other cars is my CLS6. Sometime around May of 2017 a bolt that holds the alternator to the block just sheared off. I had just bought my new truck for personal use, and was daily-driving my work truck, so I didn't bother much with it and just let it sit.
I ended up towing it down to Tomball from Denton and proceeded to let it sit for a few more months until I finally made a winter project out of it. I pulled the engine, removed the broken bolt by slotting it with an angle grinder (some superficial damage to the block as well), put a new one in and put it all back together. Again, I had no rush to get it completely done, so I didn't 100% finish until July when my dad needed to borrow a car. It was running like a dream when I gave it to him.
I know I keep spouting off all of the Texas cities like you all know where they all are, but look at a map if you care enough. My Dad lives in Tyler, where he took the CL. He drove it for about a month and THE BOLT SHEARED OFF AGAIN!!! I couldn't believe it! I used a new from Honda OEM bolt when I put it all back together. I torqued it to spec and tensioned the new belt to within the appropriate range. I am at a total loss as to how this could have happened.
He, being 200 miles away from me, took it to a mechanic to have it looked at. The mechanic tried to use a right-angle drill to get it out, but was unable to get it to budge.
They were drilling NEXT to the bolt instead of along its centerline...
So of course, it wasn't going to budge when they put an extractor in there.
Of course, I didn't know all of this until I got the car trailered back down here to Houston and pulled the engine. So now I'm left with a predicament. I can sell the car complete for parts. This will net maybe $1000 from someone who really only wants a transmission. Or, I can go get a $300 J35A3 from the junkyard if I can find one with decent compression, do the swap and get it back on the road. At which point I can sell it for maybe $2000. The car has the dreaded Honda clear coat fade, and a couple of decent dents in the doors where the fenders on the car-hauler hit it. My last option would be to get my spare J35A3 short block, rebuild it with new rings and bearings, the pistons from the J32A2, and buy all new seals. Then I'd have a high-compression J35A3 with the J32A2 cams. That would run me another $300 in parts for those. Honda is proud of their bearings and rings. At that point, I'd sell it for nearly the same $2000.
I appreciate anyone who has read this far. I'm really just venting because my garage is taken up with an immobile project that I didn't ask for, which requires me to spend money on it that I don't want to, only to not have an ideal end result with any scenario.
What would you do? I'm leaning toward the last option just to get the block out of my way, too.
__________________
Old 10-01-2018, 11:03 PM   #143
NH-503P-3
CB7tuner Member
NH-503P-3 is cool... so far.
Keep the motor. Part the car. In that case I need some of the wiring and plugs lol. I’m sorry bro I’m no help.
__________________
~Mark~
Old 10-01-2018, 11:23 PM   #144
Jarrett
Contributing Member
I have no shortage of J-series engines. I have the even higher compression J35A3 I built for the CB, as well as a newer J35Z3 shortblock, and 3 6-speeds. An extra engine is just something else I'd have to make space for.
__________________
Old 10-02-2018, 11:04 AM   #145
Grumpys93
Contributing Member
I vote last option. No point in pulling a junkyard motor that you know nothing about and hope it works out. Especially if it could cost you more then rebuilding the motor. I would also go as cheap as possible on doing the rebuild if you plan to sell it. i.e not getting honda bearings and pistons and go with eBay
__________________
~Nick~
Old 10-25-2018, 03:41 PM   #146
Jarrett
Contributing Member
Beyond. Stoked. Right. Now.
It's not completely done, but it's been over a year's wait. Ascension Motorsports is transitioning over to work exclusively on race cars, so this is one of the last two or three that he's doing for average Joe consumer. I'll take it. Still need to firm up some chassis integration, but I'll talk to him about that stuff later.
Here it is:
This will allow my J35A3 (with CL-S6 crank and cam sensors) to interface with the AEM Infinity 6 and integrate the flex fuel sensor and VSS for the EHPS. It's also wired for my electronic boost controller, but that won't be part of the initial plans. Just want to get it running, first.
__________________
Old 10-25-2018, 04:14 PM   #147
CyborgGT
CB7tuner Member
CyborgGT is cool... so far.
Damn. When even wiring harnesses can look that pretty, it really annoys me how dirty an engine bay gets from just driving around.
__________________
Slowly but surely... and gunning for that NA list!
Old 10-25-2018, 05:34 PM   #148
Grumpys93
Contributing Member
That’s a nice looking harness!
__________________
~Nick~
Old 10-25-2018, 08:48 PM   #149
NH-503P-3
CB7tuner Member
That harness is sweet. It would take me a year to build that too! Lol
__________________
~Mark~
