Old 10-18-2018, 10:07 PM   #1
djALBINI
djALBINI is cool... so far.
axle issues H22a Accord SiR t2w4
Got an issue, klunky feeling doing left turns, like it binds up after my H22A swap.
Factory setup was the f22a1 lx coupe A/T 92.
Now running JDM H22A from 94 Accord SiR mated to a t2w4 LSD M/T.
I could put the 92 accord pass. side axle from the A/T on there in place of the M/T 94 accord axle.
Does anyone know of a solution to this dilemma?
I have been scouring axle/H swap threads/google and cannot seem to find anything for this JDM 94 Accord H22A SiR application.
djALBINI is offline   Reply With Quote
Old 10-19-2018, 12:28 AM   #2
lbus9168
lbus9168 may have said something they shouldn't have...
I'm assuming you've used the prelude intermediate shaft, everything needs to be accord to work. I went through the same issues and there is a difference.
EDITED AS PER NEW THREAD:
94-97 accord axles are longer, use the original Auto Axle instead, itll work
sold! But here's my build thread for those interested.
lbus9168 is offline   Reply With Quote
Old 10-19-2018, 06:04 AM   #3
Zombine
Zombine is cool... so far.
Yep. I used my factory RH side auto axle, And a Manual LH side axle and intermediate shaft from a CB3 I'm fairly sure it was. All works fine though
Zombine is offline   Reply With Quote
Old 10-19-2018, 09:20 PM   #4
djALBINI
well, ive got the new cardone axles in place that are made to fit my 92 lx MT, unfortunately the jack shaft that connects the left one to the trans is still the same that came with the JDM 94 accord SiR motor.
I guess we will find out if this setup works.. if not im driving an hour to get the right one asap
Old 10-19-2018, 09:44 PM   #5
Jarrett
If the halfshaft has a female end for the driver's side axle, it shod be the correct one, either way.
Old 10-20-2018, 03:03 PM   #6
djALBINI
The JDM Accord SiR half shaft did not work because it has different inputs and would not accept the cb axle. Thanks to a buddy, I had another one that did. Hope this helps someone in the future.
