why i faild emissions test ?[IMG
this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid CapacitiesTags: None
Hard to give specifics without some info on your engine's health. Also you should add other measurements to your post. But see the link below for info and common tips.
http://www.smogtips.com/failed-emissions-test.cfm
http://www.smogtips.com/failed-high-...onoxide-CO.cfmLast edited by Tishock; 06-21-2012, 02:23 AM.
Originally posted by tishock View PostHard to give specifics without some info on your engine's health. Also you should add other measurements to your post. But see the link below for info and common tips.
WHAT CAUSES HIGH CARBON MONOXIDE (CO)?
Below are common faults which are likely to produce high Carbon Monoxides (CO). Carbon Monoxide is a by-product of incomplete combustion. Carbon Monoxide exceeding maximum limits, can be due to a number of emission failures ranging from inadequate air intake to defective engine computer sensors.
1. Dirty Air Filter - The number one overlooked emissions component, yes, "emissions" component is the engine air filter. A dirty air filter will absolutely restrict air flow, thus disturbing the proper 14.7:1 air/fuel ratio required for optimum fuel combustion.
We recommend replacing the air filter at the manufacturer's required intervals; usually every 15,000 miles, or at least before your vehicle's smog check.
2. Faulty Oxygen Sensor (O2 Sensor) The Oxygen Sensor is responsibly for delivering information to the ECU (engine control unit) or ECM (engine control module) relating to the oxygen content in the exhaust stream after it has left the combustion chambers.
The engine control computer will determine how much fuel to inject into the combustion chambers based on this data. The more oxygen in the stream, the more fuel the computer will deliver, and visa-versa. A defective O2 sensor will cause increased carbon monoxide emissions. More about oxygen sensors.
3. Defective Manifold Absolute Pressure (MAP) Sensor - The MAP sensor determines the level of vacuum created during an engine's intake stroke, and sends this information to the ECU. During low vacuum the MAP sensor assumes the engine's throttle is in some degree open, meaning you've stepped on the pedal. It relays this information to the ECU. The ECU, in turn, sends commands to the fuel injectors, or carburetor, to increase fuel delivery.
A defective MAP sensor will not report the correct information to the ECU, thus disturbing air/fuel ratio. Usually when the ECU senses a defective MAP sensor it will learn to ignore its data, and rely on preset values, and other sensors such as the Throttle Position Sensor (TPS), and Engine Coolant Temperature (ECT) Sensor; Fuel delivery will not be as accurate and high CO may result.
Miles:
Which Type Should I Choose?
Related Links:
Failed High HC Emissions
Failed High CO Emissions
Failed High NO Emissions
4. Defective Throttle Position Sensor (TPS) - Obviously a very important emissions sensor; the TPS relays information regarding the position of the air intake system's throttle plate. The throttle plate, located after the engine air filter and before the intake manifold controls the amount of air entering the combustion chambers. It is usually manipulated by the gas pedal via a cable. On late model vehicles the throttle plate may be controlled electronically. A defective throttle position sensor will confuse the ECU into thinking the vehicle's operator is demanding more or less fuel, when neither is really neccessary. Most often a faulty TPS will cause high CO, as an engine's ECU always prefers to send more fuel rather then less, in an effort to avoid a lean fuel mixture and subsequently higher engine temperatures.
5. Defective Engine Coolant Temperature (ECT) Sensor - Low engine temperature requires more fuel. When the ECU is unable to determine what the engine's accurate temperature is, it will not adjust fuel delivery properly; resulting in high CO. As explained above, the Engine Control Computer prefers to send more fuel rather then less to avoid a lean fuel mixture.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by ferenza View Postits near passing so it cant be anything big. a little maintenance might push it back under like an oil change , new air filter, gas treatment.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Throw some of that Guaranteed To Pass Emissions Test Formula in your shit. My car failed and I used it and it most definitely passed. Its just temporary but if you need your smog test immediately then I would atleast try it.
I guess you can't be too surprised your shit failed. You screen name is Accord Problems, lol.
Originally posted by Accord problems View Posti changed the cap rotor plugs and wires today write befor smog do to a miss fire.
If you have a cone ,clean it.
WIpe the throttle body out
Run a little bit of super in the tank and get it inspected again.
You numbers are not high enough to be any of those things on that list.When the sensors go haywire you would have probably failed alot higher than that which would as throw off your Nox ppm too.
wish i could i dont own one . i know how to use it but aint got it. called auto zone ( crap store ) they dont loan them out . called oreillys they got riped off . ya the city of theifes . looks like its time to spend 40 f ing doller to have it checked .this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
ok last night i putt in a new o2 ngk , fresh air filter with stock box , oil oil filter again , did the same thing to day . i dont get itthis was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by wed3k View Postslow or lazy o2. have it checked dawg.
post the rest of the readings. we need to see EVERYTHING
The guy who mentioned guaranteed to pass lol! Try reading the back lable next time.
t
1993 CB6 Coupe Seattle Silver YR-94M
Originally posted by Acclude4gens are win. It's in the bible somewhere.
Members Ride Thread
1993 Accord Coupe- Summer ride
http://www.cb7tuner.com/vbb/showthread.php?t=130064
1995 Civic Coupe - Winter/DD
http://www.cb7tuner.com/vbb/showthre...53#post2744953
Originally posted by HardInThePaint View PostThrow some of that Guaranteed To Pass Emissions Test Formula in your shit. My car failed and I used it and it most definitely passed. Its just temporary but if you need your smog test immediately then I would atleast try it.
ok i pulled apart my hole egr system and it was all cloged up . would that be the co readings ? i would post more pics but my shity 20 camra took a dump.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
