ive noticed that every once in a while my car wont start. i used to own a 90 civic and they were notorious for these problems. it seems to have the same symptoms as the civic. it hasnt died while im driving yet*knock*knock like my civic. so just wondering if its an issue with cb's like ef's. if so has anyone done a DIY yet?
main relay issues
Tuff
I took mine out just to learn it was fine. I was a BI**H! to get to... Its waaaay up there and i scratched the crap outa my hand and arms trying to get it out. I bolted the cruise back up but just tucked the relay behind it, so I don't have to sweat it to get to it again... Took me a good 20-25 mins till I finally unhooked it... Nine_deuce was there just staring at me while I struggled and giving me words of encouragement, ("...ooh man, that looks like a bit%h to get to...") Haha.
_____________________________________________
2 year ASE Certification/Auto Technician Degree completed
Originally posted by eazyduzit509 View PostI took mine out just to learn it was fine. I was a BI**H! to get to... Its waaaay up there and i scratched the crap outa my hand and arms trying to get it out. I bolted the cruise back up but just tucked the relay behind it, so I don't have to sweat it to get to it again... Took me a good 20-25 mins till I finally unhooked it... Nine_deuce was there just staring at me while I struggled and giving me words of encouragement, ("...ooh man, that looks like a bit%h to get to...") Haha.
I assume you are talking about the main fuel pump relay. With 3rd gen Preludes it's easy to tell when there is a problem.
When you turn on the ignition the check engine light comes on. After a few seconds it goes off (no beeping). If the light doesn't go off the fuel pump main relay is bad. Do the CB7's have something similar to this ?
Just like a starter relay, you can coax the relay to make contact by kicking it, slapping it, unplugging/replugging. Some people remove the cover and re-solder all the solder points on the printed circuit board. They swear by this.
