fender bumper gap
Sometimes when you put the bumper+bumper cover back on you have to hold it in and up as tight as you can when you tighten the nuts down. If I put it back on myself I usually have to mess with it a bit to sit right.
RIP my last two CB7s.
New rides:
'82 Volvo 245 drift project
'87 Volvo 244 daily
Born2DieApparel.com
Beat/tweak the fender to bumper bracket a bit works wonders.
02 Crv
Check for wear or damage to the slider bracket. Check for wear or damage to the screw and guide that the slider bracket engages. Check for damage where the fender zig zags from the mounted point (behind the skin in your picture); that area could be bent a little to cause the exposed edge of the fender to be higher than it should be.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
