READ THIS FIRST! (you must read this to enter the Classified Forums)
Welcome to the Traditional Classifieds section.
IF you have less than 5 posts, you are not permitted to buy or sell on this site. Please do not contact members regarding their items. Access to this section is denied to members with less than 5 posts!
If you have 5 posts or more, read on. You must read this thread carefully in order to access the Classified sections.
Buy and sell at your own risk. YOU HAVE BEEN WARNED!
CB7tuner.com has absolutely NO power to control scammers, thieves, lazy people, or the various methods of shipping. We offer NO insurance, and buying from a member in these forums is a risk.
The ONLY thing you have to go on is your naïve trust of someone you don't know, can't get to, and have never met before. Just because they drive a similar car (or say they do) does not mean they can be trusted!
Just because OTHER people have had good luck, doesn't mean you will. Each transaction is an independent event.
No whining, complaining, flaming, or "warnings" will be tolerated.
Alerting other members to a scammer is NOT permitted. You are not helping anyone by doing so, just creating a mess of flaming here on the board.
The staff has provided a resource in the ebay-only forum for your protection. If you chose to ignore it, that's on you. THAT is all the warning and protection the members here need.
So, if you choose to access these forums to buy and sell, do so at your own risk. CB7tuner.com accepts NO responsibility for the transactions that occur, and any issues WILL be handled outside of CB7tuner.com (PM communication is allowed... nothing public is permitted). No public discussion of issues will be tolerated. By accessing these forums, you agree to these terms and accept the risk. The p.ass werd to enter the forums is foglight. This p.ass word is in place so people will HAVE to read this disclaimer and accept the terms! You should have full access to the forums without having to type the p.ass word as long as you have cookies enabled, after the first time. If these rules are ever amended, the p.ass word will change. This sticky is set up so people must read it to access the classified forums. Sharing the p.ass w.ord with people who are too lazy or stupid to read this is not allowed. A one-week ban will result (longer if the banning moderator sees fit).
Sharing the password on other forums, if discovered, will result in a one-month ban minimum. That is sneaky, and not appreciated. Your "helping" is putting both new and old members at risk.
Thank you,
-Mike
deevergote
CB7tuner.com Administrator
Note: DO NOT PM, email, IM, or otherwise contact me to ask me for the password. I will not give it to you. You'll be wasting both your time and mine!
JDM Engine Goodies and other things for Sale!
    Hey y'all!
    Here is the link to my ebay selling page. There you will find the following items:
    1. JDM H22/23 OBD2 TB 60mm SOLD!
    2. JDM PDE-spec H22/23 plenum SOLD!
    3. JDM H23A VTEC engine wire harness SOLD!
    4. JDM F23A injectors
    5. JDM H22/23A injectors SOLD!
    6. JDM H22/23 fuel rail (plus banjo bolt) SOLD!
    7. JDM H22/23 fuel pressure regulator SOLD!
    8. Gates H22/23 auto timing belt tensioner (only 'cause its brand new) SOLD!
    9. JDM Tec TD-94U distributor SOLD!
    10. JDM PCB-spec H22/23 IACV (3 wire) SOLD!
    11. Gates H22/23 balance shaft belt (only 'cause its brand new) SOLD!
    12. JDM H22/23 stock exhaust manifold and black painted exhaust cover SOLD!
    13. JDM OBD2 EGR Valve SOLD!
    14. PCB stamped H23A timing side engine mount bracket SOLD!
    15. PCB stamped H22/H23A upper timing cover SOLD!
    16. 23T caliper brackets (new) SOLD!
    17. Brand new unopened Honda OEM flywheel bolt SOLD!
    18. OBD1 EGR Valve, original on my CB7, complete with OEM vacuum hose
    19. Set of 8 ARP wheel studs compatible with CB7 hubs SOLD!
    20. 36" steel braided line with 4 AN female fittings and one 90 degree neck
    21. Original, unaltered CB7 ECU: PT3-L05
    All items are FREE shipping!
    *** Think of others before thinking of yourself. ***
    MRT
    Selling on Ebay!
    15.10 @ 90.42mph
    Current fastest Laguna Seca Lap: 1:52.889
    Is it the 23T bracket that works with the 11.1" rotors or is that the 25T?
      They will work with all the Honda/Acura 23mm rotors. Some 11.1" rotors are 23mm and some are 25mm. I am still trying to figure out all applications that are workable for these 23Ts and 11.1" rotors. Here is what I have so far:
      Acura Vigor '92 - '94
      Acura 2.5TL '96 - '98
      Acura Legend '91 - '95 (Type I)
      Prelude VTEC '93 - '01
      Accord V6 '98 - '02
      I'm not sure the ITR had 11.1" rotors, but they also use the 23T brackets.
      If you have done your brake upgrade with any of those rotors, you will clear them properly with the 23T.
      I found out the hard way at Laguna Seca how badly the auto parts stores can screw up on the brackets themselves. I went through a left front pad 100%, and decided to get new pads and calipers for the 25mm drilled wagon/v6 rotors I got from TAS before they went bust. Well, I got 23T brackets in the boxes, they don't work, and here they are for sale!
      MRT
      Selling on Ebay!
      15.10 @ 90.42mph
        UPDATE:
        Just slashed prices by 10% to 30% on everything except the new Honda Flywheel bolt!
        Check it out!
        MRT
        Selling on Ebay!
        15.10 @ 90.42mph
          Wiring Harness SOLD!
          Slashed big ticket items again!
          MRT
          Selling on Ebay!
          15.10 @ 90.42mph
            Balance Shaft Belt SOLD!
            MRT
            Selling on Ebay!
            15.10 @ 90.42mph
              Just switched everything over to FREE shipping!
              MRT
              Selling on Ebay!
              15.10 @ 90.42mph
                Woohoo, just sold the exhaust manifold cover! Lowered prices again!
                MRT
                Selling on Ebay!
                15.10 @ 90.42mph
                  Stoked! Just sold the distributor!
                  MRT
                  Selling on Ebay!
                  15.10 @ 90.42mph
                    The PCB Plenum and 23T caliper brackets sold!
                    MRT
                    Selling on Ebay!
                    15.10 @ 90.42mph
                      Got another H22 Distributor?
                      Keep Pushing..
                        No sir, I wish I did. That item fetches a good amount.
                        MRT
                        Selling on Ebay!
                        15.10 @ 90.42mph
                          Just sold the 3-wire PCB spec IACV!
                          MRT
                          Selling on Ebay!
                          15.10 @ 90.42mph
                            Sold the JDM fuel pressure regulator!
                            MRT
                            Selling on Ebay!
                            15.10 @ 90.42mph
                              Just sold the H23A Injectors!
                              MRT
                              Selling on Ebay!
                              15.10 @ 90.42mph
