Windows Not Rolling Up Straight
    My window, on the passenger side front door, just started to do this thing that when i try to roll it up it will go up 98% of the way then it will act like it is catching something in the front and the back will have a little gap between the window and the seal. I took the door panel off and the window isn't catching on anything that I can see. Any suggestions???
    Time to Fix it Up
    get some silicone spray from kragen or autozone and spray the tracks on both sides...
      thanks ill try that in the morning and ill let ya know if that works!
      Time to Fix it Up
        I got the same thing but with my driver side window. I have tried the silicone spray but it only works for a couple of days and then it goes back to the same. has anyone done anything different that fixes this?
          If it won't roll up all the way, its probably your window run channel getting bunched up, not enough dry lubricant, or is broken up somewhere causing it to catch somewhere.
          Open up your window, carefully inspect the run channel (rubber piece that guides your window), check for breaks, cracks, or whatnot. If still good, it just needs dry lubricant. Do not use silicone spray as it will collect and trap dirt more. If not good, replace and apply silicone gel on the inside and sicone spray on the outside of it for better guidance.
          I did this to my drivers side window and it works great still!
          If you did both and still acts goofy, then its your window control arm and/or motor. Youtube "1aauto window motor replace" andit will have some guides on how to do so.
          "There are only two types of people in this world... Those who run & win, and those who sit at the sidelines & watch the winners pass them by."
          My YouTube Channel! - There's more videos here!
          Check 'em out, hit LIKE, or even better, stay updated with more vids when you SUBSCRIBE, including vids of my JDM H23A swap!
            Awesome. Thanks for the help. I have been using the spray and it does seem to collect some dirt after a while. I hope this works.
              Silicone is a bad idea. Graphite powder should be used. Silicone will work for a short time, and then you'll end up having to replace your window tracks.
              I wish I had seen this sooner.
              It also may be due to your window regulator needing to be adjusted. Pull your door panel and inspect it. I ignored a misaligned window for years, and the end result was damage to the mounting holes for the regulator... something that can only truly be fixed by replacing the entire door.
                Wow, replacing a whole door because of a misaligned window. Well im getting my panels off tomorrow and getting my tracks on point. Thanks for the insight.
                  i have the driver side run channel all old and abused aswell and my window goes up and down but it got caught and theres a gap between the window and the rubber channel. when I drive I here a whistle -.- super annoying and my rear right side window slides down after a few hours by itself ..... any ideas?
