i was looking at the parts i want an the body work that needs to be done and im not gonna have enough for a h22 swap and putting the motor in so what are some things to make the single cam a lil faster i have a lx non vtec motor so i kno theres not much! im gonna replace my intake,headers and exhaust is there anything else? i got high miles so im not trying to boost yet but its there any pistons or cams and stuff like that i could use?
tryin to beef up the single cam!!!
Originally posted by 94AccordCoupe View Posti was looking at the parts i want an the body work that needs to be done and im not gonna have enough for a h22 swap and putting the motor in so what are some things to make the single cam a lil faster i have a lx non vtec motor so i kno theres not much! im gonna replace my intake,headers and exhaust is there anything else? i got high miles so im not trying to boost yet but its there any pistons or cams and stuff like that i could use?
Definitly do the pistons, rods and headstuds if you plan to venture over the 8psi barrier.
You could prep your motor for boost by doing the same ^. Only issue is you should really lower compression just a touch and you would lose power in the mean time until you boost.
there is a whole performance sub-forum here that you can do some research in and actually find something out for yourself instead of expecting other people to hand it to you.
Originally posted by Stephen Fry'It's now very common to hear people say, "I'm rather offended by that", as if that gives them certain rights. It's no more than a whine. It has no meaning, it has no purpose, it has no reason to be respected as a phrase. "I'm offended by that." Well, so fucking what?' —Stephen Fry
probably the best power/bang for your buck would be to swap head or whole motor for f22a, alot better sohc platform, and bisi can do some crazy things with a f22a. and a motor would be very cheap cause theres so many around.
and yes check out performance threads and "my ride threads" to get ideas of how YOU want to build your motor and then ask more specific questions and everyone can help alot more
If your looking to go H or boost in the future why bother wasting it on your beat up F now. I would figure that the smart thing would be to save that money and put it towards the H22 or F22/F23 block to build for boost? I know you want as much power you can get for now. To install a set of Pistons or a cam costs money as well.
$1500 for a small F23/f22 boost setup or $1799 for an H22A 92-95 Motor, Trans & Computer.
If you want to save money, Pick one build and stick to your plans. Throwing cheap used parts on a motor that your just going to pull or rebuild in the end is stupid economics. Patience is the key to a nice build.Last edited by GhostAccord; 09-03-2010, 10:42 AM.
Good call, focus on what the ultimate goal is. If you want the H22 save for the H22. If you want to keep the F22, then invest in it. My main focus is my Malibu, so I decided to do cheap upgrades to the good running engine that I already had. Cam = $100. H23 IM=$50 DC Header=$60 2.5" exhaust = $150. Everything else I have spent on the car has been normal maintenance, using some upgrade parts as part of that maintenance of course!
